Need help with P2W clearances on a 2.4LR 4g64 setup.
Any motor run at higher boost with larger PTW will consume oil, it's just one of those things. Like tires or brake pads.
4.5 is fine for higher power motors.
BTW, checked all my tolerances tonite, 3 thou it is for all 4!
And for the record, Manley calls for 3.5thou on their coated pistons, 4 without coating
Thanks guys.
I called Wiseco tech. support 2 weeks ago about this same question and I'm using coated 1400HD's for my HP goal of 700+ I was told between .0045" to .0055" so I went with .005"
if you plan on 800whp, i would go to .005". looser is better than too tight. too tight will destroy the engine. too loose will make a little noise and consume a little more oil. .005" is not even that loose.
Just for the record, the 2.3 car I did with 3 thou is still running great. Makes right around 450whp, 430 when road racing. Has done a full weekend plus a few thousand street miles so far. Most motors won't/shouldn't be built this tight, but it's fine for lower power setup.
2006GSR
10
Jun 17, 2019 11:07 AM
InsaneSpeed
Jun 5, 2013 10:31 PM
2006GSR
16
May 8, 2012 09:04 AM
InsaneSpeed
Oct 26, 2011 09:14 AM
