p0011 code HELP please
Old Mar 5, 2012 | 05:51 PM
miked420's Avatar
put my stock cams back in and have a crappy idle and throwing p0011. car drive fine on freeway.
checked timing 3 times
replaces both cam sensors
even changed injectors
also checked the sensor rings
im lost at this point. any input would be great. thanks guys
Old Mar 5, 2012 | 06:13 PM
siony's Avatar
If you checked timing marks and they're ok also check if oil control valve is working and if its getting oil. If the oil passages are clogged and ocv is not getting oil it would set this code. It looks like the timing is advanced that's why it has crappy idle. You should also check if CVVT is locked, meaning is not moving in neither direction when u trying to move it.
mrbonilla
Apr 4, 2017 06:04 PM
Sheasta
Jun 20, 2016 12:38 PM
sabastian458
43
Nov 2, 2015 01:35 PM
Sheasta
Sep 27, 2015 07:52 PM
2006GSR
Sep 10, 2015 05:29 AM
