Exedy Twin Loose Bolts
Old Mar 5, 2012 | 10:00 PM
Gordian79's Avatar
Im recently drove my evo(i dont drive it too often)and started hearing a new noise(amongst the ones that are normal)Im running an exedy twin disk.Noise is from 2300-3000 sounds like if brake pad is worn and the metal clip is hitting rotor.I remove flywheel inspection cover and i find a couple of bolts pictured below are loose.I can turn them by hand.Tranny shifts fine and what not.Bolt heads look like they were hitting something.Any ideas why this would happen are these bolts sold by exedy or a vendor.Ive been looking and the only bolts advertised are clutch cover ones.
Old Mar 5, 2012 | 10:01 PM
Gordian79's Avatar
Thanks for pic STM
Old Mar 5, 2012 | 11:40 PM
tscompusa's Avatar
call exedy.. and find out what tq they should be set to and retq em to spec also.. id ask if you should use a red / blue loctite or something along those lines. those bolts should never come loose.
Old Mar 6, 2012 | 07:00 AM
delongedoug's Avatar
^ yep
Gordian79
Dec 28, 2012 06:44 PM
Gordian79
10
Dec 25, 2012 11:17 AM
Gordian79
22
Jan 31, 2012 04:37 PM
Gordian79
Jun 15, 2011 12:57 PM
Gordian79
Apr 28, 2009 05:56 PM
