bb fp black or T3 kit
Old Mar 9, 2012 | 09:57 AM
Piro Fyre's Avatar
Originally Posted by dimacoupe
gtx3076r t3 twin scroll 0.82 a/r
The biggest problem I see with this is you need 2 wastegates and you need to run more piping, meaning more money to spend.
To OP, Garrett came out with a new turbo dubbed the GTX series.
Here's the 3076R.
http://www.atpturbo.com/mm5/merchant...egory_Code=GTX
I'm planning on going T3 too but I'm getting the 3576R. From what it's advertised as, it spools as fast as a 30R but makes power like a 35R. It's a turbo that will for sure get you your 500.
Otherwise, you can go with the tried and true HTA76. Spools faster than the turbos above and that price comes with a hotside. Those GTX's don't come with a hotside and you have to buy it separately.
http://store.forcedperformance.net/m..._Code=Turbo-FP
Old Mar 9, 2012 | 11:45 AM
4ukc's Avatar
you should chose smth like 6262 definately not FpBlack, I jsut changed one for 6262
max for Black on pump is around 450whp
Old Mar 9, 2012 | 01:22 PM
Android4g63's Avatar
How much power are you seeing with the 62 and how much psi?
Old Mar 10, 2012 | 01:32 AM
Levar's Avatar
Veteran: Army
Originally Posted by Android4g63
It will be a street car. I didn't know 30r size turbos could make that on pump.
I have seen the EF4 make 500whp on pump/93 so I do not see why any 30r cannot achieve the same.
Old Mar 10, 2012 | 01:50 AM
4ukc's Avatar
I didnt do dyno yet its to cold in Ukraine ATM, but at OFF I have 1.2 bar and my double pumper with single line is finished, I did install second fuel line and that shows that definatly more than 400whp, because on Black at 1.2bar I had 400 whp
pr0phet
16
Apr 22, 2016 02:17 PM
2e0v0o3_8
Mar 25, 2016 02:54 PM
alsong2002
17
Sep 28, 2015 02:29 PM
EvilTechnology
Apr 6, 2013 09:33 AM
Mrauto50
15
Apr 14, 2012 06:52 PM
