Need Help! Idle Speed Control Motor
So my personal car is a 06 evo 9 and I have replaced the Idle Speed Control Motor 3 times .They last about 3 or 4 starts then quit working?? Has anyone else had this problem??
https://www.evolutionm.net/forums/9809532-post21.html
Your base rpm should be atleast 3-5 k to be enough to work your motor to death. It typically won't be too low because of the range of travel of the biss. Next step would be to look into voltage issues with your unit. Typically 5volts is being sent...you could have a bad regulator or bad alternator giving high output (extreme) Check manual for voltage specs. I can't find my post where I listed the voltage readings. Good Luck.
If the above doesnt give you atleast 3-4k rpm base, i would look into oltsge issues to unit. Typically 5volts is being sent...you could have a bad regulator. Check manual for voltage specs. I can't find my post where I listed the voltage readings. Good Luck.
OP, is your idle high?
well the IAC is seeing 12volts with the car in the on position but not cranked! I think it should be 5 volts but Im not really sure. The idle is perfect when its warm but when the car is cold it will not idle at all.
I am not convince that the voltage regulator is my problem! I just cleaned the TB and tighten the biss screw all the way in. Then reset the rom to stock and it cranked fine the first time so I let it fine its idle then I let it cool off and the 2nd crank was not good! But needless to say I think 3rd ISC motor is done!
