Necessary to notch block in a 2.4 L LR setup?
Old Mar 15, 2012 | 10:32 PM
2006GSR's Avatar
So me and my friend spent about 6+ hours carefully measuring and assembling my 4g64 LR setup to find out that when we installed rods/pistons 1 and 4. That they hit the sleeve after being rotated. Block is a 7bolt 4g64 out of a 01 galant.
I am really frustrated at the moment. Any help would be appreciated.
Thanks guys.
Old Mar 16, 2012 | 12:34 AM
THUB's Avatar
I didn't have sleeves put in, but my 2.4 LR hit on either the 2 or 3 cylinder, on the side of the block. I notched it with an air grinder and spent like 2 hours cleaning the block out again.
Old Mar 16, 2012 | 01:25 AM
burnzy's Avatar
you guys running turbo tuffs or H beams? H beams didn't need any clearancing
Old Mar 16, 2012 | 03:41 AM
2006GSR's Avatar
Manley turbo tough I beams 156mm rods.
Old Mar 16, 2012 | 03:42 AM
2006GSR's Avatar
I have oem sleeves. So I will have to notch the Bottom of the sleeve?
Old Mar 16, 2012 | 07:35 AM
2006GSR's Avatar
Anyone else have to notch the bottom of the sleeves?
Old Mar 16, 2012 | 07:38 AM
THUB's Avatar
The oem blocks aren't sleeved. Are you asking about needing to clearance the bottom of the cylinder bore? If so, then I did not need to using Maperformance ultimate duty rods. Some rods and some blocks need extra clearance on the side of the block, but I don't think any need it at the cylinder bore.
Old Mar 16, 2012 | 03:03 PM
2006GSR's Avatar
Just came home and took a closer look. THE RODS ARE CLEARLY HITING THE BOTTOM OF THE cylinder bore.
Old Mar 16, 2012 | 03:32 PM
2006GSR's Avatar
Figured out the problem. Piston sits 6 mm above deck. Wrong pistons.
Old Mar 16, 2012 | 04:48 PM
THUB's Avatar
That makes sense. Sucks about having to order new parts though.
Old Mar 16, 2012 | 04:50 PM
blkmkIII's Avatar
air grinder....
Old Mar 16, 2012 | 10:28 PM
2006GSR's Avatar
I ordered them trough a shop in town. Specifically said 87mm pistons for a long rod 4g64 with 156mm rods. Hoppefully something gets worked out on Monday.
Old Mar 17, 2012 | 11:08 AM
project_skyline's Avatar
You need to notch the bottom of the block with manley I beams.
benIX
Dec 25, 2016 10:35 AM
evo8lento
Jul 27, 2016 02:19 PM
Ckeesee12
Feb 2, 2016 10:15 AM
crx-si
Jan 29, 2012 10:39 AM
sarge uk
11
Jul 31, 2011 01:18 AM
