General cost for 60k service
Old Mar 27, 2012 | 06:30 AM
PatricksEvilEvo's Avatar
I know this info is probably out there somewhere but I'm in the middle of ordering a ton of parts and need to know the general amount it'll cost to have the timing belt/water pump changed. If I can get some quick responses that would be sweet. Thanks!
Old Mar 27, 2012 | 06:57 AM
psphinx81's Avatar
somewhere around 600 for parts and 600 for labor. would guess around 1200 for the entire job if you have a shop do it.
Old Mar 27, 2012 | 07:19 AM
ReignMan24's Avatar
i paid 750 for parts and labor, and that included timing belt, tensioner, pulleys, and water pump. all oem parts from mitsubishi. the shop i went to was able to get me a 23-26% discount from mitsu? alot better then payin well over a 1000$, im in OHIO which is rather close to NY, so if u want contact IPS Motorsports and see if they could possibly send u the parts at the discounted prices
Old Mar 27, 2012 | 01:16 PM
Any suggestions on which belt to get?
Old Mar 27, 2012 | 01:21 PM
evo unknown's Avatar
I like to stick with all OEM parts like belts.
Don't forget to include drivetrain fluids and coolant, etc
Also, around $600 in parts and $600-700 in labor. Call local shops near you like STM for more accurate pricing. I definitely recommend them.
Old Mar 27, 2012 | 01:25 PM
richdegrave's Avatar
I paid 785 for a shop to do it for everything parts and labor all oem Mitsubishi parts
Old Mar 27, 2012 | 02:23 PM
psphinx81's Avatar
oem or gates belt
Old Mar 27, 2012 | 02:36 PM
gsrboi80's Avatar
The VIII timing kit is 458 shipped from mitsubishiparts.net right now. Should be 200- 300 labor depending on shop just to do the timing components.
Add coolant, serp belt, etc...
Old Mar 27, 2012 | 02:52 PM
FX11's Avatar
Should not be over $1000 (USA) in parts + labor if they are just doing the simple and basic 60k maintenance. just under 500 for parts. 200-400 in labor
brenner's Avatar
i did mine myself and all in all with a new waterpump cost me about $300
Old Mar 27, 2012 | 03:02 PM
ReignMan24's Avatar
if the shop knws wat they r doing the job takes between 4-5 hours, its definetly not a quick job by ne means, but it is def sumthin that needs to b dne
Old Mar 27, 2012 | 03:03 PM
mcm308's Avatar
^ don't forget to add the cost of all the drivretrain fluids. Probably another 100 or so..
I need to purchase all these parts myself and am in a great debate.. I am probably going to order the OEM timing kit less the water pump with Gates belts and I will probably get the Gates water pump that costs about a quarter less then the OEM pump...
Old Mar 27, 2012 | 03:04 PM
mcm308's Avatar
what parts did you end up using for 300$ ?
Old Mar 27, 2012 | 03:55 PM
Blue91lx's Avatar
Do tell your secrets.
Old Mar 27, 2012 | 04:00 PM
mydnyte93's Avatar
i dont mean to jack up the thread, I have an 06 MR with just 47K miles about 6 years old. should I just wait to reach 60K miles or go ahead and do the maintenance?
