Leaking from transmission bottom
Old Apr 5, 2012 | 01:42 AM
bnr34rb26dett's Avatar
Unhappy Leaking from transmission bottom
I noticed a leak coming from transmission bottom. panel.
Its coming from that black plate on the right side of the transmission in this picture. (This is before it was damaged)
front of it is a little smashed and dented in, causing the leak. whats the best way to go about fixing this? would i need a new transmission housing? i know that i would need the transmission plating on the bottom. has anybody experienced similar issues from bottoming out and hitting a rock with the transmission?
Old Apr 5, 2012 | 01:49 AM
MR. EVO MR's Avatar
See if you can weld it
Old Apr 5, 2012 | 02:28 AM
Chef-j's Avatar
Try Jb weld see if you can stop it.
Old Apr 5, 2012 | 06:24 AM
is it even worth trying? i feel like it would come right off again..
Old Apr 5, 2012 | 10:46 AM
barneyb's Avatar
Pull the plate and see what the damage is.
Old Apr 19, 2012 | 07:16 PM
thanks
when i pull the plate, its just couple bolts on the bottom right. is there a gasket once i pull it off? i would like to purchase the gasket before hand if there is one.
Old Apr 19, 2012 | 07:24 PM
you can see the dents here. i hope its just the cover thats damaged.
does anybody know of a part number for the cover?
is there a gasket under this?
and lastly
are the screws only holding the cover in place or is it part of transmission i shouldnt be touching?
lmk!
Old Apr 19, 2012 | 08:36 PM
barneyb's Avatar
Well, I never had the cover off. Looking at the manual it appears nothing falls out and no gasket. Apply RTV and allow to set for about an hour before filling case with oil.
If you are leery of giving it a try, this should be a simple fix at the dealer.
Old Apr 20, 2012 | 06:42 AM
ok great. i just wanted to confirm that these bolts holding the cover on is not a part of the transmission. and the gasket.
Old Apr 20, 2012 | 05:03 PM
Old Apr 20, 2012 | 07:52 PM
barneyb's Avatar
Just make sure the case isn't cracked.
bnr34rb26dett
Mar 6, 2017 06:19 PM
bnr34rb26dett
Jul 10, 2013 08:51 PM
bnr34rb26dett
Jan 10, 2013 04:21 AM
bnr34rb26dett
Nov 4, 2012 09:53 PM
bnr34rb26dett
Aug 31, 2012 09:02 PM
