Mini battery
Old Apr 5, 2012 | 11:20 AM
asu11's Avatar
Mini battery
Well I am ordering my UICP today and cannot decide if I want to go short route or not. Reason being the mini battery. I live in AZ so I am not too sure how good it will hold up. Are the batteries still not good for evos? I drive my car at least once a week. Help me decide! I like how it cleans up the engine bay, but dont want to be stuck jumping it alot.
Old Apr 5, 2012 | 11:28 AM
thepoint4life23's Avatar
I would not wast my money on non short route. so just get the mini battery and call it a day
Old Apr 5, 2012 | 11:57 AM
dastallion951's Avatar
personally man, id just buy a relocation kit, and put your battery in the trunk. Worth the money, and besides your pulling the battery out of the hot engine compartment, thus going to make your battery last longer. I spent about 300-400 with an optima red top and relocation kit. took a couple hours to install.
Old Apr 5, 2012 | 12:04 PM
asu11's Avatar
Only reason not to do that is I cant run at the track :/
Old Apr 5, 2012 | 12:18 PM
Vivid Racing's Avatar
A properly relocated battery is perfect for the track. At least by NASA and NHRA rules, that is.
Old Apr 5, 2012 | 01:01 PM
Ev0ikon's Avatar
1+ for battery in the trunk.
Old Apr 5, 2012 | 01:49 PM
asu11's Avatar
Dont you need a battery cut off switch in the rear?
Old Apr 5, 2012 | 01:57 PM
Broham's Avatar
i had a standard uicp long route. The throttle was a little laggy so i went to short route ets. the amount of weight saved is nuts and the battery starts every time. I'd not even hesitate. Just don't run heavy subs sound system etc. I just have head unit and stock speakers.
It moves heat away from your uicp, cleans up bay, removes weight and removes over 1 feet of piping and bends. It is the way to go
Old Apr 5, 2012 | 01:59 PM
metalsaber's Avatar
Depends on what event you are running.
Old Apr 5, 2012 | 02:31 PM
even if u do need a battery cut off switch there really not that hard to install. Ive seen a few how tos on here. Personally ive only been told one time to have a cut off switch installed at the drag event. You can mount a switch in the cab. But in reality most of us dont track every day or week, so put the battery in first then eventually install the cutoff switch prior to the track event.
Old Apr 5, 2012 | 02:47 PM
bbyevo8u's Avatar
cbrd has a nice short/uicp and you get to keep the big battery.. http://cbrd.mybigcommerce.com/cbrd-2...-battery-tray/
Old Apr 5, 2012 | 03:12 PM
Depends on what rule set you're trying to meet. But like I said, a PROPERLY relocated battery (which includes the cut off for certain events/sanctioning bodies) is great for the track.
What events are you trying to run?
Old Apr 5, 2012 | 04:00 PM
blknblubkrdude's Avatar
I have been running the long route ETS recirculated for a year now and It is great.
I'm now going with speed density, so I ordered a short route with a tial flange so I can run my Synapse DV to atmosphere with the adapter flange. I am expecting a slight improvement in throttle response.
Keep in mind the long route may interfere with a aftermarket intake.
I personally think the Odyssey PC680 will give you no problems in AZ. Its the extended periods without driving that will kill the battery.
Good luck!
Old Apr 5, 2012 | 04:14 PM
johnnydemz4G63's Avatar
definitely go short route, amazing throttle response and de-clutters your bay. +1 on short route
Old Apr 5, 2012 | 11:15 PM
asu11's Avatar
Thanks for everyone input. I think im going the mini battery route. Anyone recommened any kits? Or individual batteries or trays?
