TESTED: Stock FPR capabilities
Old Jun 10, 2016 | 08:15 AM
  #31
High_PSI's Avatar
So 340 lph and drill the return? That's it?
Old Jun 10, 2016 | 08:18 AM
  #32
LetsGetThisDone's Avatar
Idk about the 340lph pump..
Old Jun 15, 2016 | 07:25 PM
  #33
2winscroll's Avatar
Drill out the inlet of the rail also, use an 11/32" drill. The inlet is only about 3/16" unmodified.
Old Dec 2, 2016 | 03:35 PM
  #34
Raceghost's Avatar
Can you elaborate on this please? Maybe a picture for us layman's?
Old Dec 3, 2016 | 12:38 AM
  #35
deylag's Avatar
Originally Posted by forskin fred
You don't drill anything because it's NOT the problem.
The problem is that the FPR can't flow what even a 255 litre pump can supply.
The first post on this is "manipulated data" because 14.4 volts at idle is unrealistic.
Why do you think 14.4 volts at idle is unrealistic?
Old Dec 3, 2016 | 12:49 AM
  #36
Raceghost's Avatar
I have an AEM FPR, and it can flow more than a 255, 320, or even a 420 LPR pump.
Does that change anything?
I also have an upgraded rail too.
I also through tuning, and upgraded alternator/battery/earth system, idle at 14.1~14.3v...
Old Dec 3, 2016 | 01:00 AM
  #37
Klaiceps's Avatar
Don't mind him. He's sh*tposting in multiple threads about how everyone's issues is related to fuel pressure. One of these days someone is actually going to take his advice and do some damage to their motor.
Old Dec 3, 2016 | 01:15 AM
  #38
Raceghost's Avatar
I'm just beginning to wonder if he thinks the 2.0L/2.4L SOHC is anywhere near the 4G63. Lancer base, vs EVO is a totally different animal. I just wish he would clarify, and go more in depth with his suggestions, rather than being one line board busters. Keeping an open mind and being objectionable is key in a social setting like this forum. Learn to think out side the box, or back up your logic with valid data. Simple as that.
Old Dec 3, 2016 | 09:29 AM
  #39
Raceghost's Avatar
You've already damaged your motor because you've taken wrong advice from here.
You should be old enough and wise enough to never listen to kids.
WHo's that meant for???
Frankly, you've been on here very limited, and still have no credit with your suggestions. I've kept an open mind with you, and asked you multiple times to validate your logic with data. Clarify your point of view with data, and all you do is toss BS as though you own an EVO. Where were you in the disassembly phase, where were you in the R & D phase?
Quite frankly, I know enough people in the real world that know and can validate most of the suggested mods and settings that are listed on here. Them and Myself included were driving what sounds like before you were out of diapers.
Put up or shut up. Learn some tact, and quit the shenanigans like you have been around from day one. Some of us have been.
Old Dec 3, 2016 | 11:04 AM
  #40
RazorLab's Avatar
Just stop replying to him. Trolls go away when nobody cares.
nor11384
Apr 1, 2017 03:23 PM
razorlab
Dec 6, 2016 08:45 PM
Black_EVO_MR
Oct 30, 2016 07:18 AM
Ckeesee12
Sep 13, 2016 12:13 PM
3gevoclipse
Sep 13, 2016 12:03 AM
