Going E85
Old Apr 22, 2012 | 11:50 AM
fastyouth1313's Avatar
Question Going E85
Found out there was an E85 pump near my house. I was wonder what is all needed to make the switch.
I have a walbro 255 and deachwerks 880s I know I'll need a tune. I was just wondering what else is needed or recommended. Headstuds? Better head gasket? Ect....
Thanx in advance!
Old Apr 22, 2012 | 03:29 PM
gpfury86's Avatar
Lot's of threads on this. Are those the only mods u have? Why did u need 880's if ur car is stock otherwise? Or are they not in ur car yet?
Old Apr 22, 2012 | 03:36 PM
lghtngyello03's Avatar
I'm doing the swap to E85 myself. I am on PTE 880s right now, and they will not be enough for my goals on E85, so I will be going to FIC 1450s. What are your other mods, as well as what are your power goals??
I'm also on a Walbro 255, but mine is the 255HP (high pressure) pump. But the regular 255 should be good.
Also, I am on stock headgasket and stock head bolts. I plan on keeping my boost under 30psi right at 27psi where I am now. I will eventually put studs in, but I am not half *** doing it and doing them one at a time. I will wait until my head needs to come off then put a Cometic headgasket and some ARP studs at that time.
Do you plan on switching back and forth between E85 and pump gas? If so, get a Tactrix cable and a small netbook.
You can find the Tactrix cables on here pretty often, and I bought my HP netbook off of Ebay BNIB with the factory seals still on it for $270.
I just got my injectors in the mail the other day, so I am anxious to get some E85 power myself.
And there are a good bit of threads on here about this, check the alternative fuel section out.
Good luck man!
Old Apr 22, 2012 | 06:13 PM
my mods
my mods are map EF2 turbo, buschur ported ex mani, map ported intake mani W/mil spec TB, ams fuel rail, grimmspeed 3port. greddy TBE.
i was looking into going to like 1000cc FIC's do you guys suggest going larger? ill be around 28-25psi.
p.s. i just turned 100K miles.
Old Apr 22, 2012 | 07:37 PM
gpfury86's Avatar
ya 1000's would probably be enough, but not gonna have any room to grow. My 1200cc injectors are at like 80-85% idc on stock turbo with a 255. I am gonna need to go bigger though for my new setup. Head studs never hurt, but don't think its a huge necessity. People run stock head gaskets with lots of power. Detonation lifts heads.
eliruiz
Lancer Engine Management / Tuning Forums
Jun 11, 2017 07:10 AM
PalmTreeZ
E85 / Ethanol
Apr 6, 2017 06:40 PM
Mr. Castle
E85 / Ethanol
12
Oct 13, 2015 06:46 AM
ghui99ss
Mar 25, 2010 10:08 AM
Jim in Tucson
E85 / Ethanol
Jul 21, 2008 09:16 AM
