bulletproof drivetrain!
hey guys! i want a built drivetrain that can handle alot of horses and torque and launches without failing, my goal for my car is 700 hp...what parts do i need to upgrade to achive a bulletproof drivetrain?
right now my drivetrain is completly stock!
just got mine all done by shep. generally you will need the trans built with a billet output tube and the transfer case built with hardened aftermarket ring and pinion and quafie or wavetrac diff.
No such thing as bulletproof drivetrain. This will never be a subaru. But you can give yourself the best chance by optioning up everything from shep's website. Billet output tube, stage2 or 3 tcase, quaife/wavetrac front diff, and REMing everything.
rem isnt going to make it any stronger.
what about driveshafts,axles?
Yea rem's effect on strength is very debatable. Supposedly it decreases friction, heat, wear and fatigue. Which may or may not actually amount to something practically speaking. But its not like its going to add a huge expense to a full drivetrain build.
The other thing in the drivetrain that you should consider is the clutch. You said you are looking for 700hp, but your torque figure will be more important for determining what type of clutch to buy.
Plus you may want to have the rear diff rebuilt depending on how many miles it has on it. My tcase and rear diff are currently being rebuilt by shep.
Shad
Shad
At 700 hp the clutch isn't even considered a part. It is a consumable like gasoline.
