Simple Turbo Upgrade
fp green
i had an fp green with just injectors, fuel pump, intake pipe, and an intercooler kit and it made 413 awhp so for a few grand you can definetly get good power off of that line of turbo's. also if you want a 30 series or a 35 series ATP makes them with a stock location, internally wastegated setup which are ball bearing and will make big power.
if you have a exhaust and downpipe, if your pulling to replace your turbo, yes I would buy the 02 housing, as the stock 02 has to be swapped regardless. Now on your question about the megan 02 housing, im not a fan of it personally, but if you are gonna do it and buy that, have it ported and coated. Megan's have a notorious issues of boost creeping at HIGH boost. Now ask yourself whats your hp goal? 400? 500? 600? and are you staying on pump gas or go with e85 or meth injection?? If its 400 I would look into a cbrd bbk full or an fp green or fp red. There stock appearing turbos with slightly later then stock spool up. As far as the ball bearing vs journal bearing, it is a toss up, ball bearing will last longer, and be slightly quicker (100 or so rpms) faster spool up. However journal bearings can last as long. I have a 64mm journal bearing fp red that has almost 40k on it that ive been running at like 26 psi for past few years hasnt kicked the bucket yet haha. With your mods, I would buy an intake which I didnt see listed, an 02 housing (invidia or titek imo) in addition to the turbo upgrade. Or if you have e85 available you can stay on a stock turbo and boost like 30 psi, make almost 400 hp on stock turbo. and max your stock setup, because bang for the buck, a turbo is a good upgrade however at your mods, your not fully supported for it. For the price of a BB turbo, you can buy a set of cams arp head studs springs retainers installed, and a new intercooler and piping installed. If you have already purchased your 1000cc injectors n pump, youll get close but be able to get away with running e85 without high injector duty cycle %. Get close to a goal of 400ish hp. That would borderline set you up with supporting mods, prior to a big turbo. To be honest I didnt buy my turbo till my engine blew, but only things i had left to put on were a bigger intake mani and throttle body by the time my turbo went on.
So with the right gas and money spent you can get close to your goal, and then eventually surpass it with the turbo upgrade.
Good luck if you have any more questions feel free to ask.
-Injen intake with upper and lower hard IC pipes
-1000cc Injectors by Injector Dynamics
-Walbro fuel pump
-Megan Racing Exhaust manifold, downpipe, and catback exhaust
-Invidia o2 housing
-FP Green turbo probably journal bearing
-Skunk 2 intake manifold <--- I just looked into getting one of these
If you want to economize then get the FP Green HTA 73 unported, with the FP 18# actuator, non-ball bearing. But, also consider the CBRD BBK-Full and the CBRD BBK-B(especially the B). Alternately there is the MAP EF2 and the MAP EF3.
For fitting I can say the bbkfull was very easy. Since you have a IX you can reuse the compressor outlet pipe, (I even reused the VIII, but it required modification of starter lug). All water and oil lines were reused and just required mild bending to fit. Other than that it was like swapping out the stock turbo.
Make sure the turbo is primed prior to installation. After it's installed, to remove air in the oil and to start circulation, turn engine over with starter and with the crank sensor plug disconnected
I agree with what was stated above. But if 400 is your goal you can get there on the stock IX turbo. I am so close and my mods are not that insane. I am looking to get an FP green BB just to get better power and not max out my stock turbo.
I think the most important thing is to get a MBC and a solid tuner, The tune is really key. I put down 371 with stock airbox, LICP, Injectors, DP and exhaust and 269 cams. Just throwing some other options at you. THe FP Green can get expensive after you add it all up so you could get supporting bolt ons with out touchign the turbo..
That being said you really cant go wrong with an FP or a BBK
Thanks so much! and yeah I did forget to mention that I got the Injen intake with hard uppper and lower IC pipes. And my goal is around 400 and I haent bought the o2 housing yet so instead of a Megan Racing ill go with an Invidia. I also see what your saying about pushing a stock setup to the limit but I want my setup to reach my 400 goal without having to put some serious ware on my car. So do you think I can reach my goal with these upgrades?
-Walbro fuel pump
-Invidia o2 housing
-Walbro fuel pump
-Invidia o2 housing
That Megan exhaust manifold is notorious for cracking. If you have the OEM manifold I'd put that back in. You already have some bolt ons so I would just add cams, MBC, and a tune and worry about a turbo later on since your only shooting for 400hp.
Edit: guy above beat me to it lol
Well what are some good exhaust manifolds because im tired of the OEM one its rusted and makes my bay look awful. I was looking at the ram horn invidia exhaust manifold? shouldnt that be good enough? and what kind of cams do you think I should get?
those all look except imo, i would change 2 things one the megan racing exhaust manifold once you start pushing power youll run the risk of cracking the manifold they usually end up cracking at the merge collector. Second, I wouldnt buy the skunk 2 intake manifold there have been some issues reported on that intake manifold as far as fitment goes, and seen some graphs and while its an improvement its not a big hp improvement. Personally I would look into a a Map Rev series intake manifold thats what mine is, I have a map rev 2 intake mani, they look stock but there ported on the inside. Real good thing especially if you live in state thats become so anti cars its not even funny. So if you do that buy a 65mm throttle body milspec something like that, that way your not bottlenecking your system. But imo, an intake manifold and throttle body will give you about the same hp as a good set of cams. So if i was in your position I would hold off on the intake mani and throttle body and do cams first either s2, or kelford with some head studs if you can swing it springs/ retainers. I like my s2 cams. When the time comes down the road to the intake mani and tb, the airflow will be consistent coming in and out, rather then large volume coming in, and cant be pushed through and out the engine as fast, due to stock cams.
