Simple Turbo Upgrade
I need to know the most simple possible turbo replacement upgrade, and by simple I mean basiclly direct bolt in the stock turbo location. I mean yes I do want a bigger turbo and I don't want an OEM one but I've seen that most turbo upgrades force you to make alot of modifications to your car like to the manifold or BOV location and other things. I don't have much done to my EVO IX at all, the only thing I have thats aftermarket that is anywhere near the turbo is the Megan Racing exhaust manifold, Megan Racing downpipe, and a GoFastBits TMS response BOV. My goal is to find a good turbo instead of an entire turbo kit that is an improvement from stock but wont require too many modifications. The last bit of info I can provide that might help is that my EVO is NOT my daily, it is just my weekend get away car and I do NOT race it or take it to the track what so ever, the most action it sees is just some agressive street use. Any ideas?
Most turbos are going to require more fuel because they force more air into the cylinders. So u are going to need a pump, injectors, and tune. I am not sure a black will suit you very well.
Yeah I kinda figured I would need a tune but lets say I do get some new 1000cc injectors from injector dynamics and a walbro fuel pump then whats the answer to my main question? What kind of turbo is the next best thing above stock?
Compressor Cover
-84mm Surge Port
64mm Stock Appearing
Wastegate Actuator
-Stock EVO 9 Wastegate
-18psi/930mmHg
-25psi/1290mmHg
Porting
-None
-Ported (+$95) <-------Can you give me a small explaination of what "ported" means and if its worth the extra $95
Bearing Type
-Journal Bearing
-Ball Bearing (+$800) <-------Is getting a ball bearing setup worth the extra $800? or can I just go with the journal bearing?
but speaking of exhausts should I get the megan racing o2 housing too?
Your pretty much set if you are planning on doing injectors, pump and a tune. I'm s fan of Cbrd stock appearing turbos. I believe there slightly cheaper than forced performance and turbos are just as good if not better it's really all opinions there very close in performance. O2 housing mine as well do it when you swap turbos since your already in there
I just looked into those turbos and they are around the same price as the FP green and actually the ones I've found are more expensive than the FP turbos so I think I'm going to stick with getting an FP green
They are usualy slightly quicker, and have a longer life expectancy. It's up to you, I wish I would have gone with the ball bearing, but it was just coming out and not proven yet. Also I think MAP also has stock frame turbos.
