HKS GTII 7460 - What to do?
Old May 2, 2012 | 10:00 PM
fightex's Avatar
following up on this thread - HKS 7460 failures
Originally Posted by Spool4Fun
Here is the WG flapper that warped that Aaron was talking about. History of the turbo... bought from Ivey, installed and tuned by English, one track day.... problems from the turbo, English adjusted the actuator arm, second track day... more problems, then turbo came off the car to see what the heck was going on.
http://youtu.be/MAFeMtqKxhg
tightening the WGA after every successive track day brought back some response but it's still laggy and not hitting target boost which leads me to believe it might have a warped wastegate flapper as seen in the above video. i've since gotten new LICP/UICP/intake/BOV, there are no leaks and the compression is perfect across the board. the turbo has the same amount of shaft play as when i got it and it doesn't smoke.
i got the OG non-kai 7460 used with 200 miles (currently has less than 10k miles) from an EvoM member and a DBB Red is going in place of it in a few days.
can i send it back to HKS Japan? or have a shop machine a MHI hotside for it? what are my options as far as getting it fixed and what are the costs associated?
any input is appreciated
Old May 3, 2012 | 02:08 AM
94AWDcoupe's Avatar
machining mitsu hotside would improve turbo. the HKS is like 9cm very restrictive.
you can also fix the HKS by installing new flapper valve . can be made to seal flat again with new angle the warped arm created.
Old May 3, 2012 | 02:24 AM
fightex's Avatar
i guess installing a new flapper valve would be the most economical option. do you have any idea where i can buy one?
thanks for your input
Old May 3, 2012 | 12:08 PM
94AWDcoupe's Avatar
http://store.forcedperformance.net/m...de=Acc-Flanges
Old May 3, 2012 | 12:20 PM
SPANKED's Avatar
Good find... hopefully I won't need this anytime soon for my HKS, but good to know where to find one.
Old May 3, 2012 | 06:40 PM
sparky's Avatar
So is the original HKS 7640R flapper valve a 34mm diameter face? I guess so, huh?
Old May 3, 2012 | 07:24 PM
Joshthree6three's Avatar
one could also weld it shut and go with an external wastegate.... cheaper than a turbo, but more expensive than the flapper.
BB FP Red's make a pretty stout car as well.
Old May 4, 2012 | 01:55 AM
fightex's Avatar
i was going to give the HKS away for dirty cheap, now you've saved me a bunch of money. appreciate it
Old May 9, 2012 | 12:23 AM
fightex's Avatar
final question, what is a fair price for the turbo as is? $750? $1000?
Old May 9, 2012 | 06:40 AM
cfdfireman1's Avatar
I understand some people had a problem with the turbine housing moving on the center cartridge and loosing preload because of it. There is no locating pin on these turbos like on the stock units.
Old May 9, 2012 | 06:26 PM
sparky's Avatar
Originally Posted by cfdfireman1
...some people had a problem with the turbine housing moving on the center cartridge and loosing preload because of it. There is no locating pin on these turbos like on the stock units.
Wierd, huh? It sure is a funky actuator rod configuration. I did not know about the center housing clocking though. That would just further complicate things. The actuator rod is not a single piece. The metals stretch. Now, the center housing clocks. Funky!
Old May 9, 2012 | 06:34 PM
Benja's Avatar
$500 posted down under?
Old May 13, 2012 | 11:52 PM
fightex's Avatar
there are 2 guys ahead of ya, i'll let you know if it falls through
looks like the flapper is not seating properly
Old May 14, 2012 | 01:06 AM
Benja's Avatar
Please do!
PM here or bjperry@gmail.com
Cheers mate.
LCS
19
Feb 9, 2017 11:15 AM
LCS
11
Mar 31, 2016 07:58 PM
bruce988jl
Jan 16, 2016 07:38 PM
EvocentriK
172
Apr 21, 2015 07:40 PM
