Can stock 8 cams sound like this?
Old May 4, 2012 | 12:31 PM
marcusE's Avatar
Yup, 3D01 and 6A is marked on them.
So what gives.
Old May 4, 2012 | 12:53 PM
JohnBradley's Avatar
The EGR lines are routed correctly? Sounds like it might not be and the EGR is open at idle.
Old May 4, 2012 | 01:00 PM
marcusE's Avatar
Hmm potentially swapped? There is only two lines right?
Old May 4, 2012 | 01:06 PM
meckert's Avatar
Those are some wide lobes on that cam... that and the idle and vacuum would all suggest cams. I assume you could make stock cam lobe as well by advancing the intake several degrees and drop the timing at idle--but thats all BS-- your car sounds good.
Old May 4, 2012 | 02:12 PM
marcusE's Avatar
I love the way it sounds now lol and as long as the power is still there.. I'm not too worried about it even on stock cams.. It's a mind boggle.
Old May 4, 2012 | 02:14 PM
Correct. I inadvertently did that one day and noticed it made an audible difference in the idle. Not saying thats it but something to check anyway. Fits your description and then it would have knocked hard before in the 5K+ range and now probably everywhere.
Old May 4, 2012 | 03:34 PM
marcusE's Avatar
Hmmm I'm on e85.
Old May 6, 2012 | 07:07 PM
marcusE's Avatar
Update: Switched EGR lines and that was not the problem..
I do have A IAT high output code being thrown.
Going to EGR block off from STM next week and replace the sensor.
Tom says no way to tell if they are stock stilll.
Old May 22, 2012 | 05:54 AM
marcusE's Avatar
Just an update : stock cams CAN sound like this and they did..
I fixed a major leak on the EGR then this happened..
Once I drained the ecu reflashed and did EGR block off, it idles perfect again.
Old May 23, 2012 | 12:41 AM
Evo2372's Avatar
Hi there so marcusE are you saying that the lumpy idle was due to a leaking egr?
We couldn't find anything wrong with my car and it sounds like yours in the clip.
So does yours now sounds different?
Cheers.
Old May 23, 2012 | 01:47 AM
stunt2's Avatar
how to disable EGR, just blank the hole with some plate, blank vacuum lines and that's all ? any modification deeded in rom ?
Old May 23, 2012 | 11:29 AM
EVOeroc's Avatar
They don't sound stock at all. My stock came were more steady and almost no lope. I have buddyclub 272's and they sound a little rougher than those
Old May 23, 2012 | 05:54 PM
marcusE's Avatar
Cheers.
Once I reflashed it with the EGR blocked off and removed completely..
Vaccum went back up to normal 20-21 and it idles 100 percent now..
It was the tune compensating for the leak in the EGR.
Fix your EGR system then drain ECU and reflash your tune and let it idle for 20 minutes.. Should be good.
These are stock evo 8 cams btw.
Old May 23, 2012 | 09:53 PM
cmspaz's Avatar
A buddy of mine's does this too, I checked over the EGR lines and stuff tonight, but since it's been confirmed that an EGR leak causes this, I'll let him know.
Old May 24, 2012 | 12:59 AM
Evo2372's Avatar
Thanks marcusE, will have a discussion about this with the tuner... Pollution gear at its best...
fostytou
359
Oct 23, 2025 09:54 AM
marcusE
Feb 18, 2012 04:43 PM
dac001
Jun 23, 2011 05:37 PM
project_skyline
13
Jun 25, 2009 08:32 PM
hawaiian_evo
Evo X How Tos / Installations
Apr 14, 2009 03:44 PM
