Building 2.1 with 4g64 block
Old May 4, 2012 | 07:06 AM
evoboy2006's Avatar
Smile Building 2.1 with 4g64 block
I an I'n process of building 2.1 with 4g64 block. I have few question of any one can help me will the 4g63 head bolt right up with no modification to the head as having combustion area machined? One more question I'm using 156mm rod Is there any company that sells 10:5:1 compression pistons for this setup with out geting custom thanks
Old May 4, 2012 | 10:42 AM
evoboy2006's Avatar
Bump
Old May 5, 2012 | 08:30 AM
Spec-Ops1's Avatar
Originally Posted by evoboy2006
I an I'n process of building 2.1 with 4g64 block. I have few question of any one can help me will the 4g63 head bolt right up with no modification to the headache as having combustion area machined? One more question I'm using 156mm rod Is there any company that sells 10:5:1 compression pistons for this setup with out geting custom thanks
Yes you can bolt the head up without having the combustion chambers machined, however your compression ratio will not be 10.5:1 anymore...
Manley makes the piston in question...
606215C-4 86.5mm Bore, 156rod, 88mm Stroke, 1.375" Comp. Distance, -2.5 Dome Volume, 47 / 43 Cylinder Head CC, 10.5 Compression Ratio, Flat Top design, 352 Grams
606220C-4 87mm Bore, 156rod, 88mm Stroke, 1.375" Comp. Distance, -2.5 Dome Volume, 47 / 43 Cylinder Head CC, 10.5 Compression Ratio, Flat Top design, 360 Grams
Old May 5, 2012 | 09:13 AM
evoboy2006's Avatar
If I brought manley pistons with 10:5:1 leaving the chamber not machined my compression will be higher ? Thanks man
Old May 5, 2012 | 12:57 PM
Spec-Ops1's Avatar
Correct, a tad higher
Old May 5, 2012 | 01:34 PM
evoboy2006's Avatar
Leaving it like that I'm gunna be running e85 either way... But leaving the chamber can that cause detonation only reason I ask it because I seen threats saying people have issues when they leave it thanks again man
Old May 6, 2012 | 01:06 AM
AreSTG's Avatar
this is NOT based on experience, but more rumors i've heard. nonetheless, worth doing some searching on...
Heard that not modifying the head can lead to head gasket failures, which people used to talk about a lot whenever the 4g64 was brought up. Don't hear it as much these days, but maybe everyone is modifying the head now too. But, i don't know, maybe the problems were form increased compression or something.
Old May 6, 2012 | 08:10 AM
sparky's Avatar
How does Manley arrive at the advertised comp ratio values for their pistons?
Assuming identical stroke and the same combustion chamber shape and volume and given the stated fact that both flat-top pistons, by definition, have identical non protruding flat top designs. Piston 606220C-4 should have a marginally higher compression ratio than piston 606215C-4 due to its slightly larger bore size compared to that of the other piston, all other things remaining equal. At least I would think so. Unless there is something else that I am no taking into account.
Old May 6, 2012 | 08:27 AM
evoboy2006's Avatar
Yeah I'm wondering the same with unmachines chamber and manley 10:5:1. Compression what the compression be? An if I would have head gasket issues? I would like to hear from 2.4 guys and 2.1 making high hp.
Old May 6, 2012 | 09:54 AM
Spec-Ops1's Avatar
No clue... I am not an engineer... This info was straight outta the Manley Catalog...
Old May 7, 2012 | 10:01 AM
evoboy2006's Avatar
Thanks tho maybe dome other people will have input
KOOLER
Jun 2, 2017 08:23 AM
foxbat
11
May 14, 2017 11:38 AM
Ichigo0Soul
May 23, 2016 09:02 AM
wesleylawson6
Lancer Engine Tech
Jan 7, 2015 05:27 PM
jbeaton9292
Nov 30, 2014 01:05 PM
