Evo 8 HS on a Evo 9 compressor housing
Old May 10, 2012 | 11:55 AM
korizmo's Avatar
It seems this question doesn't come up to often. Not even google could help me.
The only reason I ask is my 8 turbo went bad. I'm not able to find a decently priced 10.5 hs for the evo 9 compressor side I just bought or when I do people buy those like their GOLD. Till I find that 10.5 HS or go on ebay for the 11.5/10.5, can I run my 9.8 on the 9 turbo for the time being. It wont be like this but for a few weeks if that.
Thanks and when people search maybe they will find this thread.
Also another question. Why was my turbo hitting 30lbs of boost on the stock evo 8 wastegate (no boost leaks found). It started to do it before it went bad.
Old May 11, 2012 | 02:09 AM
Yogi_B's Avatar
All evo4-9 exhaust housings are interchangable. It's only the compressor housing on the 9 that isn't interchangable with evo4-8s and vice versa.
Old May 11, 2012 | 04:29 AM
sparky's Avatar
As Yogi mentions, the 9.8 turbine housing per se, will bolt right up, as the VIII and IX are both configured with the same turbine wheel. In addition, that turbine housing will mate right up to the backside of the center housing and the flange will bolt right on up to your exhaust manifold and DP too.
The only fitment issue with respect to the turbocharger unit itself will be that an VIII actuator is not gonna work in conjunction with the IX compressor housing. You will need the IX actuator.
Of course you already know about the install kit consisting of oil and water feed and return lines as well as the IX J-pipe, right?
Old May 11, 2012 | 04:30 AM
korizmo's Avatar
Thanks I really appreciate it. Luckily I was able to find a 10.5 hs yesterday for a good price.
Old May 11, 2012 | 05:00 AM
sparky's Avatar
PM me as I am interested in purchasing a 9.8cm Turbine housing.
TwistedEvo8
10
Mar 18, 2012 07:27 AM
Darkn3s
Feb 20, 2012 12:06 PM
speedfreak0920
Nov 18, 2010 10:23 PM
scarface2jz
26
May 25, 2010 11:33 PM
Nastynine
For Sale - Cars For Sale
42
Mar 28, 2010 10:55 AM
