Hyd TOB compatibility
Old May 12, 2012 | 03:44 AM
ch53avitech's Avatar
Are the Exedy hyd clutch components compatible with QM hyd clutches and vise versa. I'd really like to convert to hyd TOB but am torn between the Exedy kits AMS sells and the QM MAP sells.
Old May 12, 2012 | 06:58 PM
Bump
Old May 12, 2012 | 07:05 PM
n2oiroc's Avatar
i would imagine of you get the exedy push pressure plate and measure everything according to quartermasters instructions (using the exedy clutch and quartermaster tob) it would work just fine if you shim/grind the tob to the proper clearance.
GHEvo8
10
Nov 1, 2014 01:52 PM
jonzie04
Sep 3, 2012 10:13 AM
My03evo
Mar 14, 2011 01:32 AM
EVODreams
Jan 9, 2011 07:32 PM
