Can't bleed clutch
Old May 13, 2012 | 07:55 PM
EVOWRC111's Avatar
Question Can't bleed clutch
So, I replaced my clutch with a ACT 6 puck, replaced all my lines with AMS steel braided lines and removed the slave cylinder pill. It's working great and was bleed 3 times but after some launches the pedal only comes half way back up. The spring is good and working as well. The pedal comes all the way back up after like 5 seconds but still doesn't seem right.
Old May 13, 2012 | 07:57 PM
thedru13's Avatar
did you rebleed it? make sure air is all gone
Old May 13, 2012 | 08:22 PM
cfdfireman1's Avatar
the reservoir portion for the clutch doesn't show too well. it's the part closest to the firewall and is very hard to see, it will look like it's up to the full mark but the back part can be low. best thing to do is fill the thing all the way up to the neck keep it there and bleed again.
Old May 13, 2012 | 09:43 PM
EVOWRC111's Avatar
I read about that and did over fill it but have the same results. It's bled and feels good but when I get into the gas I still have the same problem. I'm using dot3/dot4 fluid. Could it be the temp?
Old May 14, 2012 | 07:54 PM
EVOWRC111's Avatar
Well, I bled it 2 nore times and the clutch feels great, once it warms up it will only come up half way in 4th and 5th gear, only if I get into it hard. If I cruz normal then its fine... wtf?
Old May 14, 2012 | 08:25 PM
barneyb's Avatar
I'd say something is binding in the pressure plate once it gets hot.
Old May 14, 2012 | 08:48 PM
does the clutch slip when this happens?
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
hiboost2.0
Mar 23, 2016 05:38 PM
Rumblefish237
16
Sep 1, 2011 02:26 PM
mauisurf2003
Lancer Troubleshooting
Sep 23, 2007 03:14 AM
shiftdsm E
Sep 12, 2007 10:37 PM
