Proper fluids?!?!?!
Old May 14, 2012 | 07:53 PM
xtruemassacre's Avatar
Proper fluids?!?!?!
I got this fluid from Mitsu dealership for the transmission. Will it also work for the transfer case?
In addition to the above question. I am in the middle of a clutch install and removed the banjo bolt in order to get at a t-case bolt. What fluid is needed to replace that and or is that the same fluid needed for the transfer case?
Old May 14, 2012 | 08:02 PM
BlackonBlack2's Avatar
the transfer case and transmission take 2 different fluids .. i know the transfer case is a red diaqueen box like that one... i'm not sure which banjo bolt ur referring to
Old May 14, 2012 | 08:06 PM
its on the passenger side top of transfer case. it's connected with a cooper line and this banjo bolt.
Old May 14, 2012 | 08:09 PM
PeteyTurbo@KHC's Avatar
Thats the line for the ACD. Good luck..
Old May 14, 2012 | 08:11 PM
right, but since I disconnected that line, I need to fill it up. is it the resv. thats in the trunk? ATF-3 iirc?
Old May 14, 2012 | 08:13 PM
xRoguex's Avatar
key to on and hold down gas pedal for 5? 10? seconds.... pump will kick on. Just open bottom bleeder when its running and shut before it stops.
Old May 14, 2012 | 08:15 PM
thanks I read and understand that from previous theads. I'm now trying to figure out if that fluid I drained by removing that banjo bolt is Tcase fluid or from the ACD resv...
Old May 14, 2012 | 08:20 PM
xRoguex's Avatar
acd fluid. The tcase is self contained..
Old May 14, 2012 | 08:22 PM
which ACD is ATF-3 right?
Old May 14, 2012 | 09:07 PM
xRoguex's Avatar
i think so
TomekEVO
May 30, 2015 03:27 PM
khaoswing
Outlander Sport
May 24, 2014 04:16 AM
INCaneFan
Aug 9, 2010 05:00 AM
hahnsolo
Jun 22, 2010 08:53 PM
r32gtr94
Jun 5, 2008 11:21 PM
