2003 evo 8 hitting fuel cut?
Old May 15, 2012 | 09:05 AM
Nevolution's Avatar
I recently purchased a 2003 evo 8 that had been in a small front end collision before i bought it. The car has an Invidia turbo manifold, and the intercooler, radiator, and wastegate actuator have all been replaced. Before he crash the car is said to have ran fine but now hat it is together again i seem to be hitting fuel cut under higher load in 2nd gear and up. It is not RPM specific just seems to be occuring under higher load conditions at 19 to 21 psi which is all the higher boost im running. Sometimes it jerks violently and other times it is minimal but it is always noticable might not be fuel cut because there i no boom factor but it feels like a boost cut or something alng those lines. I have already tried new plugs gapping them to .023. Not that it matters but just to add more detail the car has a slow-boy racing stage 2 block. to my understanding everything else is stock. Looking for a little bit of advice if anyone else has had a similar problem. Boost seems to stay steady on the gauge as well
Old May 16, 2012 | 10:41 AM
suekie's Avatar
Do a boost leak test.
If the car has been sitting for a while, drain the fuel tank and get some good reputable gas (i.e. Chevron)
Old Jan 6, 2013 | 05:37 PM
MR.Maxwell's Avatar
Bringing this 6 month old back..I am having a similar issue. 2003 evo 8, stock besides 4" Intake, greddy boost controller, and boost gauge. the car has 95XXX miles on it, and was boosting at 18-19 psi. Now There was no specific incident or accident that could have brought this on, but now I can not push the throttle wide open with out the car bucking in between 10-15psi. I Can slowly accelerate to 7000 rpm, but the second I give it more it bucks and seems to miss fire. I bought some new spark plugs and the stock gap is at .32? thought these need to be gapped to .26-.28? Any adive will be appreciated!
Old Jan 12, 2013 | 10:01 PM
sparky's Avatar
Originally Posted by MR.Maxwell
..I am having a similar issue. 2003 evo 8, stock besides 4" Intake, greddy boost controller, and boost gauge. the car has 95XXX miles on it, and was boosting at 18-19 psi. Now There was no specific incident or accident that could have brought this on, but now I can not push the throttle wide open with out the car bucking....
Has your Evo been tuned?
Old Jan 13, 2013 | 02:58 PM
MR.Maxwell's Avatar
It hasn't.
Old Jan 13, 2013 | 03:27 PM
10isace's Avatar
It hasn't.
What load are you hitting at WOT when this happens?
Old Jan 13, 2013 | 03:36 PM
MR.Maxwell's Avatar
If I go WOT it shakes/stutters/bucks at about 10 psi.
Old Jan 13, 2013 | 04:33 PM
10isace's Avatar
Can you put up a log of when this happens? Can you log with evoscan?
Old Jan 13, 2013 | 04:37 PM
uhhhson's Avatar
possibly the coil packs
Old Jan 13, 2013 | 06:41 PM
MR.Maxwell's Avatar
Unfortunatly I dont have evoscan yet, wont be able post a data log. If it is the coil packs, is there a way to specificly check them?
Old Jan 13, 2013 | 06:44 PM
4RETECH's Avatar
Gap the plugs to .22, then let us know. ESP in winter with cold dense air.
Old Jan 13, 2013 | 06:53 PM
uhhhson's Avatar
find a friend with an evo and borrow his
Old Jan 14, 2013 | 04:21 PM
MR.Maxwell's Avatar
This morning I pulled the plugs, and the gap was over .37? I cleaned them, and put them at .22-.24 and the issue has gone away.
Thanks for the help.
Old Jan 14, 2013 | 07:02 PM
4RETECH's Avatar
Glad it was an easy fix.
Old Jan 15, 2013 | 01:59 AM
triple L's Avatar
stay away from champion plugs from peb boys i had them and they still backfired... ngk iridiums ftw
