Balance shaft delete kit
Old May 23, 2012 | 03:45 PM
DrDeC's Avatar
Hey guys I had my balance shaft bearing go bad on my VIII and I have to replace it so I want to just put in the delete kit from ams. How hard is the job? What should I do and what shouldn't I do? How can I do it without removing everything?
Old May 23, 2012 | 03:48 PM
DrDeC's Avatar
Also, will the timing of the delete kit make a difference at all? Or will te shaft go in and sit fine no matter what?
Old May 23, 2012 | 03:57 PM
okevolutionVIII's Avatar
It's a pretty involved job, I did mine with the engine out and it still took some time. The timing on the new shaft can sit anywhere, just have the crank and cam gears in time and you're good to go.
Old May 25, 2012 | 12:05 PM
DrDeC's Avatar
What tips would you give me in doing it? Also what things don't I have to remove to do the job?
Old May 25, 2012 | 12:11 PM
You'll need to remove the oil pan, all sprockets and pulleys from the crank, timing belt, balance shaft belt and gears, both bearings for the rear shaft and other things I can't think of ATM. It will be a major PITA with the engine in the car but can be done.
Old May 26, 2012 | 08:39 PM
jason42003's Avatar
Its def easier to be done with the engine out but like the previous guy said it can be done with it in. I would suggest pulling it out if you have the time and ability, I pulled mine in a day (full 12 hrs) by myself.
Old May 28, 2012 | 07:10 PM
DrDeC's Avatar
I have a lift and most other tools, so I can try to pull the motor, any threads with a detailed how to? Or just go with what the manual says? Where also can I get the specialty tools I might need? Thankd
Evo47
Feb 8, 2017 01:51 AM
TrendSetter
10
Nov 4, 2015 06:16 AM
IXEvolutionIX
10
Sep 3, 2009 06:11 AM
EvoAlex48
Jul 25, 2009 02:56 PM
SPOOLEDTSiAWD
75
Nov 25, 2007 09:09 AM
