Stock radiator fan control + manual switch?
Old May 31, 2012 | 09:59 AM
killerpenguin21's Avatar
can it be done?
i havent been able to find much info. i daily drive as well as track my car. with the random high heat and humidity we've been having lately i got to thinking that i would like to have a back up to the stock fan control. i will be adding an oil cooler fan, and wouldnt mind having a higher cfm slim fan on the radiator also...all running on a single "fans" switch.
i have already tweaked my fan control maps, so i dont foresee an actual overheating issue, but i like to be over prepared, as well as the fact that it wouldnt hurt to be able to run the fans manually for cool down purposes after a session.
any info would be appreciated.
Old May 31, 2012 | 10:01 PM
really, no one?
Old Jun 1, 2012 | 05:50 AM
Davo's Avatar
what is high heat?
what water temps u see?
Old Jun 1, 2012 | 08:41 AM
been 85 degrees and 90% humidity for days now. like i said, the car has not gotten hot yet, but id still like to be able to run the fans to move air through the engine bay between sessions.
Old Jun 1, 2012 | 08:48 AM
MechTech's Avatar
Unplug your a/c compressor before a track day and turn the a/c on and off to activate your fan ( your a/c must function normally in order for this to work). Unless you really feel like wiring in your own circuit.
EDIT: Nevermind, I don't think this will work if the car is off with ignition on.
Old Jun 1, 2012 | 09:25 AM
blitzkreig's Avatar
it can be done. you have to use a relay. will check back my wire install and let you know.
Old Jun 1, 2012 | 10:10 AM
thanks. no issue doing the wiring. i ran across a posting of the wiring diagram with a possible circuit drawn, but there was no confirmation that it worked.
are you running the stock fan, or a slim with the stock control + switch?
05LSMx
Lancer Troubleshooting
Apr 13, 2024 02:08 PM
Alchem1st
Mar 15, 2022 08:47 AM
araz5260
Feb 19, 2017 09:18 AM
evo8tanner
11
Feb 4, 2017 08:32 PM
lghtngyello03
10
Jul 22, 2016 03:26 PM
