Dipstick blow out
Old Jun 4, 2012 | 08:18 AM
dan08's Avatar
Dipstick blow out
Ive been having dipstick blow out on my Evo and I don't know why. I have eliminated my pcv valve and im running a ventilated catch can. I have the manifold line plugged and running both lines on the valve cover to the catch can. Any boost over 30 psi is when I get the dipstick blown out. Current mods are:2.3 stroker, fp black, kelford 272's, all supporting mods on e85 (road tuned up to 30 psi till I get my double pumper in). Any thoughts on what I may need to do or whats going on?
Old Jun 4, 2012 | 09:36 AM
Spec-Ops1's Avatar
Higher crankcase pressure due to built motor... put a spring on the dipstick to keep it down, you can get one in the help section at any autoparts store...
Old Jun 4, 2012 | 09:48 AM
thepoint4life23's Avatar
Cant you run a line from the back of the block as well to help bring the pressure down
Old Jun 4, 2012 | 09:51 AM
dan08's Avatar
I planned on just throwing a spring on the dipstick but I had the same issue on my stock motor at or above 30psi. I did not have a vented catch can though. So now im just wondering why Im having the same issue with catch can.
Old Jun 4, 2012 | 10:00 AM
okevolutionVIII's Avatar
I would start looking at a more serious crankcase vent setup. On my build, I was forced to run huge ring gaps which caused a ton of pressure so I'm venting the valve cover and block. Running larger ports off the valve cover and venting the dipstick tube would be a big help.
Also, if you're not using the port on the intake to pull vacuum, I would do that 1st as that will use the turbo to suck the pressure out of the system.
Old Jun 4, 2012 | 10:11 AM
dan08's Avatar
I forgot to mention I do have the balance shaft delete.
Old Jun 4, 2012 | 12:33 PM
s.e.a.n.'s Avatar
Use the spring as mentioned above everyone I know with an evo making decent power has the same problem.
Old Jun 4, 2012 | 12:55 PM
jaysonsyl's Avatar
Spring
I had same problem sounds pretty common I just threw a spring on there
Old Jun 4, 2012 | 01:39 PM
dan08's Avatar
Im gonna go ahead and try that. I just purchased a vented dipstick off another member on here so I will vent the dipstick as well as throw a spring on there.
Thanks everyone
Old Jun 4, 2012 | 07:45 PM
fantrman's Avatar
Did you install the vented catch can on the IM side or on the turbo inlet side? Why did you eliminate the PCV? Is this a race-only or a street engine?
Old Jun 4, 2012 | 07:57 PM
AJsGenerX's Avatar
I think Buschur Racing sells a spring kit for the dipstick. Ask David. He can certainly help you out.
Balrok
Apr 19, 2016 10:47 AM
Titish
18
Sep 6, 2014 09:02 PM
strtrcng426
Sep 20, 2010 02:12 PM
evoal83
40
Feb 8, 2008 04:20 PM
David Buschur
68
Jan 24, 2008 11:13 PM
