can anyone give some common on the exedy twin disc?
hi guys, my oem clutch is about to go out at 63 now, and i have a used exedy twin disc laying around. but never have a chance to put it on the car. so before i acturally do that i will like to ask you guys that have experience of using the twin disc some question. and my car is not heavy mod, i only have intake and exhaust, and boost control that boosted to 26psi.
so here is the question:
is it much harder on the pedal? cause i mostly use for street
since it is use, is there any way i can measure the disc how much is left? any spec for that?
last question is it has a 10mm flywheel bolt that was broken and stuck in the housing. trying to get it out. and can i just order the 10mm bolts and the washers from exedy?
thank you if some one can please give some advise..
I have the twin in my car. basic bolt ons..... I can't answer the last questions but as far as pedal feel I love it. Very easy on the leg.. I daily drive my car and have an hour commute each way. So I really like the twin.. I went from an ACT HDSS so this is much nicer... Hopefully someone else can chime in on the other questions. ..
phillybuilt
12
Jan 3, 2016 05:58 AM
2006GSR
11
Apr 14, 2015 01:18 PM
FS[Mid-Atlantic]: Carbonetics triple disc clutch
Technical10
Dec 10, 2014 05:26 AM
subrwho
23
Jun 25, 2010 03:38 AM
