EVO 8 HELP ! I have $1000 to Spend, What do i do ?! i want WHP.
You will need tuning if you mod your evo with exhaust, cams, intake, etc.......its the best way to extract the most out of your mods/upgrades....
Do some research and spend your money wisely...I'll admit I did NOT take the best mod approach to my evo due to a lack of research. I would have saved me time, money (at least a couple thousand dollars) and frustration of dealing with poor customer service because of my choices.
+1 on buying used parts on forums, most of the performance parts I have were bought here.
There's a lot of options on parts, I'd start with an intake and lower intercooler pipe, and full exhaust. I like ETS stuff but you'll get more for your money buying good, used parts.
Do i gain hp ? and how much ? And where should i purchase this ? Also is it loud because im looking to go louder because right now im on a quiet magnaflow -_-
I have only been to GST. They replaced my clutch and I purchased pads and SS brake lines from them in the past....great group of guys from my experience.
Where will i be approx whp and hp wise ?
I would suggest a ported oem exhaust manifold, otherwise you'll have to put the stock one back on to pass smog......and a complete TBE ... not just a downpipe....If you can get some good cams too...that will really open up your evo 8.
I have 280 HP on a DynoDynamics dyno...from Vishnu...it is a low reading dyno from what I've been told...so I would be over 300+ HP on most other dynos... Get a baseline stock HP dyno figure then again after you are done with your first round of mods.
You being in Cali-- you're limited to 91 octane and restricting Laws in Cali governing modifications .
New walbro ---> $50 - 65
New drop in filter ---> $15 - 25
Port your stock intake ---> cost 'time'
MBC ---> $25 - 45
Port your exhaust manifold ---> cost 'time'
Used O2 housing ---> $35 - 55
Definately LICP ---> $45 - 75
Tune (*support your vendors/ tuners on the site) ---> $200 - 400
Go to Vegas a blow ther remaining change, if you win big PP me some funds. GL.
MBC ---> $25 - 45
Not saying don't do it...we are simply trying to bring light to the bigger picture of modding...
And what do you think about this ?
http://www.ebay.com/itm/3-EVO-7-8-9-...7013e6&vxp=mtr
MBC ---> $25 - 45
MBC ---> $25 - 45
And do you highly reocmmend the boost controller or just whatever ?
If i win big i gotchuuuu
Not true...just make sure to hold on to your stock exhaust...trust me...at the very least, your cat. Intakes can be frowned upon too. A friend had to put his oem intake back on to pass the visual....
