Why is my 4g64 w/Evo VIII Head Perfectly in Time?
The timing with a 4g64 belt on a 2.4 lines up as it would w a 63 belt on a 2.0 it's fact it's been done over and over again on multiple motors to the same effect
Logically thinking if you turn your cams bak one tooth and then turn your crank back one tooth everything must stay in sync from that point on yes? Yes...
Thus when you go to tdc on the crank w a 63 belt you are off half a tooth due to 6mm of deck height. Now go measure the distance from tooth to tooth on a belt it's in the realm of 11 mm therefore 6mm of that is taken from the deck leaving you off by 5mm or about half a tooth which is why you need to degree the cams.
W a 64 belt the 6mm from the deck + the left over ~5mm is made up for in the extra one tooth thus leaving you with as close to perfect timing as one can get (same as timing a 2.0 w a 63 belt) varies a degree or two depending on how much was cut from you head and block etc
EVO 1-3 are one way and 4-9 are the other. Read the instructions again. I have used a lot of these gears and always put the EVO hole on every EVO8 and they lined up. I used them the other way on DSM and they are right. I would hate to see your car run like crap because the timing belt is off. Mine was and it was a pain to figure out. I didn't do the belt the first time and took for granted it was right. Poor vacuum at idle and barely ran. Lucky I didn't bend valves.
I posted a picture of my dowels in the EVO hole, and everyone told me to put them in the non-Evo dowels. I did the change and my car ran perfect, and timing lined up.
So, I just kept it the same. For the car to even run with the gears in the other position the ignition timing had to be absolutely nutty. When I put them where they are now, it ran perfect with a normal ignition timing map.
That's a whole other dilemma I guess....
Again, thanks for all the help in this thread. I've heard far too many things from far too many people without any logical statements to back it up, so when I timed my car a number of times and it lined up perfect, it didn't make sense to throw it off from the beginning, until what Batty said about accounting for the 6mm twice.
k, one more try and I'm done....
the 64 belt is one tooth, 12mm longer to make up for the 6mm deck height up and down. from the crank gear to the cam gear only offsets 6mm of this length because the belt passes it once, obviously. soooooo 63 belt comes up 6mm short, half a tooth short, and the 64 belt comes up 6mm long half a tooth long...
clear as crystal yet or will you just believe me when I tell you I'm right...
the 94 galant is the only car mitsu put the 63 head on 64 block and for some reason those engineers decided to move the cam dowel and mark half a tooth... the answer is described above
anyone else wants to disagree get out the degree wheel and realize your wrong...
/thread
/thread
/thread
/thread
Just throwing a bunch of facts out with no support doesn't go so well when someone asks a question purely based on logic, you feel?
Now I get to do it:
/thread
I totally feel you and understand your confusion. This topic is always a mess dude. The only reason your having a hard time is because of all the people spreading the wrong info. Its an easy concept once you consider the measurements.
as they say, "the math doesn't lie."
just remember
is how I roll
just remember
is how I roll
.Now to rip the lower timing cover off in the car. This will be a blast.
Exactly. I got told so many different things it was unbelievable, so I resorted to math, but my math was off because I didn't know one had to account for the deck height both up and down in the equation, hence my retarded conclusion
That seems to always be the problem. next time I'll just jump straight to that explanation. Now we both learned something today.
