Galant STR/VR4 Non-AYC Diff on EVO IV - Possilble
This is what can happen with EVO IV AYC Diff if you launch it several times, this is 2nd AYC diff on my car so decided to go to Non AYC Diff
RS ones that is available on ebay is a bit expensive so got non ayc diff from 8G Galant VR4 and started installation, AYC and Non AYC diff has same 3.312 ratio so in term of drivetrain it should go smooth, all you have to do it to fit it.
Here is a diff itself, removed from 8G Galant VR4, you will also need axles from Galant VR4, note that they are 12mm longer then normal but don't be afraid, they will fit
The problem you will face during an installation is that mustache bar is not fitting bolt on at diff itself, all you need to do is cut the edge of the bar so thet it can bolt on the back of diff properly
After that everything goes smooth and installed just the same way you dissemble it
You can use, VR4/STR or 8G Galant 2.4 AWD rear diff as all of them has 3.312 ratio
good luck
P.S.
Removing AYC is the best process
good luck
P.S.
I used diff from 1998 8G Galant VR4 ear non AYC diff, its has a same gear ratio 3.312 as E4, unfortunately you can not use the same diff on E5 unless you change a gear ratio to match, E5 has 3.307 AFAIK, you can try to use ring and pinion from your AYC diff to match gear ratio, or change transfer box from evo 4 model to have a gear ratios aligned
Also you can use rear diff from EVO 8 if its available, I guess E5 and E8 ratios are the same, double check it
thread back from the dead.
So you're saying all 8th gen Galants 2.4 with AWD can be used in this conversion?
I didnt even know they came in AWD, but if thats the case tracking down one shouldn't be that hard
doncarbone
Apr 21, 2020 01:15 PM
mrwickd123
Evo X How Tos / Installations
30
Feb 20, 2019 09:29 PM
FS[Mid-Atlantic]: MD: 2011 Evolution MR, 31K Miles, $28.5K
Howat
For Sale - Cars For Sale
Aug 19, 2016 09:57 AM
Mauricio Evo IV
28
Feb 28, 2016 04:34 PM
