boost leak test FP Black w/84mm housing
Old Jun 13, 2012 | 06:34 AM
snafufx's Avatar
so I've been doing boost leak tests with my air compressor reading and yesterday noticed the 25psi that I was doing was actually more like 8 psi. So I use my AEM digital boost gauge to set things up, hook it up and the tester blows off the turbo. I've tried the hairspray, t-bolt, 2 worm clamp methods and even let hairspray sit overnight to make sure it secures to no avail. Has anyone been able to do a test with the compressor cover? It has no lip whatsoever so easily pops off everytime. Any suggestions appreciated. Thanks.
Old Jun 13, 2012 | 08:29 AM
NOMIEZVR4's Avatar
I've ran into a similar issue. What I've done is take the lower intercooler pipe off the turbo, clamp the boost leak tester onto the lower intercooler pipe and test it from there.
Old Jun 13, 2012 | 09:24 AM
211Ratsbud's Avatar
I used a piece of rope to hold the coupler to the turbo
Old Jun 13, 2012 | 09:33 AM
project_skyline's Avatar
What is your tester made of? Never had one pop off when attached to the turbo.
Old Jun 13, 2012 | 10:17 AM
CurseDSM's Avatar
Mine only did once, tighten the clamp more.
Old Jun 13, 2012 | 10:24 AM
TJs98GT's Avatar
so how does the boost leak test work? Just use some kind of attachment on the turbo inlet and pressurize the inlet tubes?
Old Jun 13, 2012 | 10:37 AM
CurseDSM's Avatar
yes if there is any leaks in the system, the pressure up to 30 lbs would find it. This is why you use smoke and or soapy water to spray down all the areas that would leak.
Old Jun 13, 2012 | 10:38 AM
snafufx's Avatar
Thanks, that did the job!!! Pressurized it to 33 psi and let it sit for 10 minutes, no leaks. My tester was made from ETS silicone reducer, want to say it was this one:
https://www.extremepsi.com/store/pro...at=1535&page=1
Basically took my old MachV tester and used it for this.
Ted B
148
Jun 5, 2025 01:24 PM
asu11
11
Sep 11, 2014 03:36 PM
SLO-EVO
45
Mar 27, 2014 11:09 AM
BlackSE
Apr 20, 2011 09:28 AM
o6RSEvo
Sep 19, 2007 11:02 PM
