Exhaust leak from dump side of muse external dump
Old Jun 23, 2012 | 08:15 PM
Brent_si's Avatar
I posted about this before. Basically I have exhaust leaking from the dump tube side of my muse external dump at idle. Its almost like the wastegate isn't closing but it builds boost just fine. I have taken this on and off 3 times, replacing the divided gasket, running no gasket, then using only copper rtv and it is still leaking!
I need to know if anyone else has had this problem asap. I have heard of someone having to adjust the wastegate actuator but no one has confirmed this or how to do it. I mainly need to know which way to turn the nuts to adjust it.
Im actually considering throwing this muse **** away and going internal again!
Old Jun 23, 2012 | 08:24 PM
sparky's Avatar
Originally Posted by Brent_si
I posted about this before. Basically I have exhaust leaking from the dump tube side of my muse external dump at idle. Its almost like the wastegate isn't closing but it builds boost just fine. I ahave taken this on and off 3 times, replacing the divided gasket, running no gasket, then using only copper rtv and it is still leaking!
I need to know if anyone else has had this problem asap. I have heard of someone having to adjust the wastegate actuator but no one can confir.
Don't toss the Muse in the trash so hastily. I am not an expert but I would say that copper RTV sealant is not going to hold up to the heat emanating from a turbine housing. No, no, no! So, it is bound to leak exhaust.
You tried increasing WG preload and this didn't help the issue?
Old Jun 23, 2012 | 09:16 PM
jwdp54's Avatar
what kind of gasket are you using? if you are using oem then that's your problem, you'll need the divorced one and map sells it.(or atleast that's where i got mine)
if that's not it then it's your preload. i had to take the nut off and cut 2 threads off to get it to close fully.
Old Jun 23, 2012 | 09:29 PM
flymx771's Avatar
Same here...FP 25psi wga by chance?
Old Jun 24, 2012 | 12:36 AM
Brent_si's Avatar
the original post says divided gasket. I have replaced it 2 times then tried without a gasket then just rtv. I took it off since I posted this again and put a new copper gasket on it with thin layer of copper rtv on each side.
Thing isn't going to get any better of a seal.
How do you adjust the preload? Just turn the nut on the actuator arm? In which direction to close it? My wastegate is just the stock one I believe.
Old Jun 24, 2012 | 03:26 PM
Brent_si's Avatar
So today i took the actuater off the turbo. Held the wastegate closed by hand as hard as i could and it still leaks bad.
Old Jun 25, 2012 | 10:55 AM
Brent_si's Avatar
im going to take it back off again and make sure nothing in damaged with the wastegate. Only other thing it could be is the muse housing flange is so badly out of shape it just leaks.
Old Jun 25, 2012 | 08:05 PM
Brent_si's Avatar
Anyone got any idea what else it could be? I really dont think its the gasket.
Old Jun 25, 2012 | 08:23 PM
sparky's Avatar
A couple of guys have already advised you as to what is most likely causing the problem. You are going to have to try increasing the tension on the WGA spring.
Old Jun 25, 2012 | 08:35 PM
sparky's Avatar
I have never personally run a dump housing on my Evo. But, I recall a couple of horror stories about the flapper valve hanging up internally on the tubing walls on some of these things.
But, I don't remember what specific brands experienced this problem. This was way back in the early days of developing these things and I am sure that those types of problems have been solved.
Old Jun 25, 2012 | 08:40 PM
sparky's Avatar
Hmmm? Didn't your fingers get kinda hot down there? Don't use your hand. Try some bailing wire instead. Or a small chain with a hook on each end and a turnbuckle to take up the slack
Old Jun 26, 2012 | 04:58 PM
Brent_si's Avatar
I did increase the tension... No my car was completely cold and only started it for 10 sec or so.
Old Jun 26, 2012 | 06:56 PM
warstang27's Avatar
get a straight edge check the dump if thats good check the turbo. if both are good its a flapper seating issue
Old Jun 26, 2012 | 08:10 PM
Brent_si's Avatar
Yea im thinking its the "flapper". Any diy ideas on how to fix it?
Old Jul 12, 2012 | 09:05 PM
Brent_si's Avatar
Can someone get me a link of where I can buy one of the divorced gaskets? Im going to try this one more time. spool times is still at full spool before 4k rmp. having a hard time believing its the flapper not sealing.
Slow208
Jan 19, 2017 02:12 PM
TTKID
68
Nov 30, 2014 05:33 PM
theEVOdream
Mar 9, 2014 10:14 AM
clubchico15
Aug 2, 2012 04:50 PM
the mark w
29
Jul 14, 2011 08:09 PM
