Clunk Noise when hard shifting after new clutch
Old Jun 26, 2012 | 01:17 PM
BoostedAWD91's Avatar
I just had the stock clutch replaced with a Exedy HD Stage 1 Clutch. I let it break in 600 miles and then i ripped on it in 3rd gear and when shift fast into 4th gear, it made a very loud clunk noise. It never made this noise with the stock clutch. Is it just from the new clutch engaging harder than the stock when slamming throught the gears?
I feel like i have to granny shift it now to avoid it when ripping on it. I know its a different car, but i could shift my galant vr4 alot harder with a shot driveline and it wouldn't clunk as bad. Is there anything that will help with this besides different style of shifting?
Old Jun 26, 2012 | 05:15 PM
EvoIIIAj's Avatar
Yes.. That's normal. Its coming from the rear of the car correct? Its the rear diff you're hearing I think. New clutch will bite harder and make you hear that sound..
Old Jun 27, 2012 | 01:15 PM
yeah its the rear diff. Guess there is no way around it except for granny shifting
Old Jun 27, 2012 | 01:42 PM
Brent_si's Avatar
you can replace bushings and that will stop it. Mine does it even on a stock clutch with 100k...
Old Jun 27, 2012 | 06:31 PM
BlazinVIII's Avatar
just order up some better mounts/bushings(mainly the differential mount) and it'll fix that
Old Jun 28, 2012 | 04:47 AM
stihlalive's Avatar
same here, just installed the same clutch too lol i like how heavy it is for a "stage 1". banging gears its very intense
Old Jun 28, 2012 | 01:50 PM
ok ill look into that. How hard is it to change the rear diff bushings on Evos?
Old Jun 28, 2012 | 01:59 PM
ElectricBlueIX's Avatar
This is what you need bro. Kind of a PITA to do. My mechanic did mine for me while it was in the shop getting some other work done.
https://secure.buschurracing.com/cat...a1d1d6b2fb2be5
Old Jun 28, 2012 | 02:37 PM
PRS's Avatar
PRS
Diff bushings like the other guys said
Old Jun 28, 2012 | 03:27 PM
Vivid Racing's Avatar
Diff bushings for sure. Not only will they solve the noise problem but they'll make shifting easier if yours are bad enough.
PM me if you need a quote.
Old Jun 28, 2012 | 05:35 PM
ok the last question i have is which one to go with... Torque solutions or energy suspension bushings? Which is the better option
Old Jun 28, 2012 | 05:52 PM
I have all torque solutions parts in my Evo and have zero complaints
Old Jun 29, 2012 | 11:49 AM
Either one is a good choice. I have the energy suspension set for the rear diff but I have Torque Solution carrier bearing bushings for my driveshaft. Love them.
selp
Dec 31, 2014 08:19 PM
weiyan8
Sep 18, 2012 10:38 AM
npham455
May 8, 2012 09:18 AM
ODUB
13
Sep 9, 2009 06:00 PM
two2thehead
Mar 6, 2004 11:49 AM
