View Poll Results: To wrap manifold or not
Wrap it up!!
26
45.61%
Keep her raw!!
31
54.39%
Voters: 57. You may not vote on this poll
Wrap tubular manifold or not??
Old Jul 11, 2012 | 11:36 AM
  #31
the1tonton's Avatar
http://www.cerakotehightemp.com/
I use the above coatings instead of wrapping. It is very easy to DIY if you have access to a sandblaster.
Old Jul 11, 2012 | 01:24 PM
  #32
03whitegsr's Avatar
Wrapping increases the chance for cracking simply because it keeps more heat in, raising the metal temperature. It does EXACTLY what it is supposed to do, trap heat in the exhaust system instead of releasing it into the engine bay. If ceramic coating worked as well as wrapping does, it too would lead to cracking also.
Easy test for the brave.
Go do a drag pass with your high end ceramic coating, pop the hood and put your hand on the header...(don't really, because it will burn the **** out of you).
Do the same with a wrapped header...you actually can put a hand on it for several seconds if it was done right without getting burned. YES, it blocks heat that much better.
Fact is, no matter how great that coating is, it's still EXTREMELY thin. You can have an exceptional insulator, but heat transfer is related to 1/t where "t" is the thickness of the material. When the good coatings are 0.010"-0.020" thick at most, they just can't compare to a "good" insulator that is nearly 1/8" thick. That's without even considering the heat transfer effect caused by contact between the materials. The heat transfer to the fiberglass only touching some of the pipe at the macro level will transfer less heat than the ceramic that is in contact with the metal at the micro level.
Old Jul 11, 2012 | 01:57 PM
  #33
Brianawd's Avatar
I coated my manifold on my Galant vr4 when I had it. I also wrapped it. Before the coating and wrap it was causing the powercoating on my valve cover to bubble. Its was also startign to cause issues with my carbon fiber hood. The hood would get so hot you could not put your hand on it. After coating and wrapping the manifold the hood was only warm. I ran that same manifold for 5 years and it never cracked.
I just ordered a new toxic fab manifold for my evo and will be coating and wrapping that as well.
Old Jul 11, 2012 | 03:19 PM
  #34
foxbear2277's Avatar
Originally Posted by akeric
high temp coat and wrap for twice the fun
only issue with wrapping is if the manifold is cheap it can accelerate cracking and breaking welds. but wrapping it will increase spool (slightly) and hopefully keep your engine bay temps a little cooler.
That is my worry now is that the mani will crack... my main purpose for wrapping it is simply to reduce heat in the engine bay due to the tubular mani from stock mani that had a heat sheild...
Very informative, didnt realize that the wrap did that good of a job over the ceramic coating... but makes sense why the mani tends to crack due to wrapping and not when coated...
Your test is hilarious but I still think I would not even touch the wrapped header after a drag pass... im not that crazy lol
Thanks for the insight and great information
Thanks for the feedback and input, its much apreciated
Old Jul 11, 2012 | 10:06 PM
  #35
st00pidct9a's Avatar
vht flameproof
Old Jul 12, 2012 | 02:19 PM
  #36
Originally Posted by st00pidct9a
vht flameproof
Ill be honest, if I was to coat it I would ceramic coat it... dont think I would ever cross thought of spray painting it
Old Jul 12, 2012 | 03:29 PM
  #37
03whitegsr's Avatar
I wonder if you could actually get a manifold nickel plated and if it would stay on after lots of heat cycles...
That would greatly reduce the potential for high temperature oxidization on the outside and prevent carbon percipitation into the metal from the exhaust on the inside.
BoostNY
For Sale - Miscellaneous Automotive
Feb 20, 2017 09:46 AM
kyoo
12
May 13, 2016 05:30 PM
novaspyder87
Mar 18, 2016 08:00 AM
Boosted Tuning
Jul 13, 2015 08:57 PM
Locdizzel
Sep 22, 2011 10:22 AM
