What is the Max AWHP for Stock 560cc Injector?
Thank you RS Mike...
Sad to say im still not sure whether my current Sard 850cc injector scaling & latency value is correct.
So far hv tried few different scale & latency but here is the value (943cc scale - 6.12 / 3.12 / 1.992 / 1.320 / 0.888 / 0.672 / 0.408) which is closes to 14.7AFR during idling compare to others scale & latency value.
But now ive 2 things to worry about :
1) Stalling issues as AFR will deep til 10AFR whenever throttle lift off especially A/C on
2) AFR doesnt goes below 11 or 11.5AFR while WOT or High Speed Run til Redline....
Other than that car, runs fine or is it got anything to do with advancing the GSC S2 cams? No driverbility issue other than improved on lower end response.
I make 402hp on the virtual dyno, but I run alcohol injection which gives me alot of extra fuel. I think my injector duty cycle is only 83% if I recall.
I guess the point is.... it is totally going to depend on your fuel and other mods. The better fuel you run, the leaner you can run, and thus the more hp you can get out of smaller injectors.
4G63 DSM
78
Feb 17, 2017 05:05 AM
WTB[SouthEast]: 2 stock 560cc injectors
mikgsxx
Nov 30, 2015 10:20 AM
WTB[Mid-Atlantic]: WTB: Stock injectors
driven168
Sep 24, 2014 01:45 PM
jameswwt
Sep 11, 2012 06:05 AM
jameswwt
Dec 16, 2010 12:27 AM
I did 404 @ wheels on a Dyno jet but the idc was at 98% if you run a non dangerous idc it will be right around what John Bradley just said.
