Broken Banjo Bolt
Old Jul 14, 2012 | 07:21 AM
KJS's Avatar
KJS
Broken Banjo Bolt
So i was finishing up my car and putting the banjo bolt from the head to the oil feed line and i guess i over torqued it and it snapped right in half. I was able to get it out of the head no problem. Where can I find a replacement? Napa? Mistu dealer? Or am i going to have to order it online from a vendor on evom
Old Jul 14, 2012 | 07:45 AM
Spec-Ops1's Avatar
I have one, too bad you arent local... may be able to get one from napa...
Old Jul 14, 2012 | 07:47 AM
KJS's Avatar
KJS
Just checked napa, outta luck there, hopefully a local shop will have one or I'm gonna have to get one over nightted from someone so its hear by monday
Old Jul 14, 2012 | 08:01 AM
Spec-Ops1's Avatar
Try a motorcycle shop as well since they use banjos on everything and it will be metric... also search for local hydraulic fitting shops as well...
Old Jul 14, 2012 | 08:03 AM
KJS's Avatar
KJS
Do you know the part number by chance, trying to get a hold of a mitsu dealer
Old Jul 14, 2012 | 08:13 AM
Spec-Ops1's Avatar
2 part numbers to try at Mitsubishi and Dodge dealer
MS650013
MF650102
Old Jul 14, 2012 | 08:31 AM
deylag's Avatar
Yea same thing happened to me and I just replaced the bolt with the same OEM bolt. Make to sure to check the torque specs on the bolt so you dont over-tighten it. The top bolt is 12 ft lbs
and the bottom is 23 ft lbs.
Old Jul 14, 2012 | 08:34 AM
evo8dreamcar's Avatar
I was in a tight bind when i broke mine, and actually made one with a bolt haha. taking it off tomorrow but has been on there for about two months no problem. a drill press did wonders
Old Jul 14, 2012 | 09:24 AM
Hendrixmx's Avatar
I did the same thing awhile ago, the new one I bought from the dealership was made from stainless steel, made me feel better about torquing it down. I believe the ones from the factory were made from brass.
Old Jul 14, 2012 | 12:33 PM
KJS's Avatar
KJS
yeah mitsu had 2 in stock, grabbed em both. let me know if someone needs one in the tristate
Old Jul 14, 2012 | 10:06 PM
Spec-Ops1's Avatar
congrats!
Old Sep 1, 2012 | 06:11 AM
Raptord's Avatar
MS650013
MF650102
I got MF650102 from my local dealer this week and it's not the one going to the head, it's the one on the turbo.
Do you have the part number? This is the bolt that bolts the oil feed line to the head, right?
TURBODAWG
10
Mar 17, 2018 04:04 AM
MechNARP
24
Oct 10, 2017 06:52 AM
Jeepyedo
Dec 14, 2015 07:20 AM
nikush
Oct 4, 2015 02:39 PM
Grimgrak
Sep 14, 2015 07:48 PM
