Compression test on a built motor??
Old Jul 14, 2012 | 07:47 AM
brakeboost980's Avatar
My buddy had a compression test done today and the numbers were 190 across the board.The shop told him the motor is bulit and they also said to him, due to the high numbers it read there's a bump up in compression ratio..Is this true??Also do bulit motors read higher then stock ones?Thanks.
Old Jul 14, 2012 | 08:03 AM
Turbo01s2k's Avatar
If the motor has high compression pistons, or a decked head, Yes, the compression ratio will be higher. If the motor has stock compression pistons, it will not be higher. Sounds like it has like 10:1 pistons in it. Motor sounds healthy though.
Old Jul 14, 2012 | 10:02 AM
apagan01's Avatar
Sounds correct what the shop said. Compression is surelly high.
Old Jul 14, 2012 | 12:56 PM
?? Anyone else let's elbarote ..This was on a cold motor by the way
Old Jul 15, 2012 | 10:19 AM
Anyone else knows. ?
Old Jul 15, 2012 | 06:10 PM
browningderek's Avatar
Stock is 9:1 and around 175psi at sea level. My motor is 11:1 and 230psi at sea level.
Old Jul 16, 2012 | 01:24 AM
TurboTravis's Avatar
Holy crap, failing all around in this thread.
Compression RATIO and compression PRESSURE are two different things.
Old Jul 16, 2012 | 02:53 AM
SOUL STEALER's Avatar
Cam timing plays a major factor in building compression. You may have stock compression but altered valve events.... Something to look at of you tear into the motor
Old Aug 25, 2013 | 11:54 PM
Cmax's Avatar
Bump on an old thread. What would make a stock block have higher compression pressure than normal?
Old Aug 26, 2013 | 10:15 AM
barneyb's Avatar
Anything that makes the piston stroke longer or the combustion chamber smaller when the piston is at the top of its stroke.
Old Aug 27, 2013 | 09:24 AM
Cmax's Avatar
So considering it's a stock block neither of those things would be possible...
Old Aug 27, 2013 | 09:48 AM
jspecteggy's Avatar
Not necessarily, can be a stock block/head but if the head has been milled that would reduce the volume inside the chamber and in turn bump up the compression. All on what appears to be a completely stock setup.
Old Aug 27, 2013 | 11:03 AM
Cmax's Avatar
I doubt that would be the case either. For my particular situation at least. Bought the car with 17k miles and I have not pulled the head since I have had the car.
Old Aug 27, 2013 | 11:21 AM
jspecteggy's Avatar
What are the pressures you're getting?
Old Aug 27, 2013 | 12:44 PM
Cmax's Avatar
195-200 across the board
