-10 AN fittings on valve cover ?
Old Jul 20, 2012 | 04:17 AM
mcm308's Avatar
I've been thinking about how im going to do my catch can setup. I plan on using -10 hose and fittings being that I already have a bunch from a previous build. I was thinking of how to get the -10 fittings into the valve cover and what type of ffittings to use. Someone said just to tap the valve cover but I need some more info. Has anyone done something like this?
Old Jul 20, 2012 | 02:20 PM
sho669's Avatar
Quite a few people have done it.
Drill & tap holes, remove baffle to clean out all the excess shavings, reinstall baffle and you're good to go. The cover being magnesium makes it a bit tricky but its a fairly straight forward process.
Old Jul 20, 2012 | 04:07 PM
mcm308's Avatar
You say drill and tap.. what about the holes that are already in it?
Old Jul 20, 2012 | 06:10 PM
sho669's Avatar
Will a 1/2" fitting fit in a 3/8" hole that isn't threaded?
Old Jul 20, 2012 | 11:00 PM
jessmanEVO's Avatar
how are people reinstalling the baffles? or are they just not running one?
Old Jul 20, 2012 | 11:40 PM
sho669's Avatar
Rivits or you can tap the mounting bosses to accept small machine screws.
Check out R/TErnie's first post in his build thread, good details on it there: https://www.evolutionm.net/forums/al...4-efr7670.html
Old Jul 21, 2012 | 01:40 AM
Lukelis's Avatar
maybe it helps you how reinstall baffles
Old Jul 21, 2012 | 01:43 AM
Lukelis's Avatar
and I have done this setup with -10AN fittings few months ago and used custom catch can with two breather filters
hydro334
Oct 20, 2016 04:44 PM
05EV08
Apr 27, 2016 08:45 PM
(03evo08)
Oct 21, 2014 03:50 PM
ch53avitech
Aug 20, 2013 07:08 AM
Lukelis
Dec 21, 2011 07:00 AM
