MAF Sensor on intake needed?
Old Jul 21, 2012 | 01:41 PM
AustinB768's Avatar
Question MAF Sensor on intake needed?
Okay so I was looking for an intake and I noticed that certain ones come with MAF sensors and some don't. Now I thought my Evo 9 came with a MAP sensor and I've heard before that you either have a MAP sensor or a MAF sensor. So my main questions are
What is the point of having a MAF sensor? and will I be okay without one?
Old Jul 21, 2012 | 01:44 PM
ch53avitech's Avatar
Your car will run poorly if you remove your MAF sensor unless you convert to speed density.
Old Jul 21, 2012 | 01:46 PM
AustinB768's Avatar
I thought Evos came stock with MAP sensors not MAF sensors?
Old Jul 21, 2012 | 01:48 PM
RoMeIX's Avatar
Bingo! Your car will idle erratically, will drive extremely rough, and may randomly stall out. Converting to speed density will eliminate these symptoms.
Old Jul 21, 2012 | 01:52 PM
We have MAP sensors and MAF sensors.
Old Jul 21, 2012 | 01:55 PM
AustinB768's Avatar
So we have both? And what does it mean to convert to speed density?
Old Jul 21, 2012 | 01:56 PM
AustinB768's Avatar
Oh okay thanks, so how come they sell cold air intakes without MAF sensors?
Old Jul 21, 2012 | 02:05 PM
The MAF sensor is mounted in on your intake prior to the turbo and it senses barometric pressure, humidity, et cetera and sends that information to the ECU which determines how much fuel is needed at any given time (whether it's a humid day, cold day, dry day, hot day, or driving in the mountains of Colorado) . The MAP sensor is mouted on your intake manifold and it determines how much air is being pulled into the engine by how much pressure is measured inside the intake manifold.
Old Jul 21, 2012 | 02:10 PM
https://www.evolutionm.net/forums/ec...d-density.html
You'll need a MAP sensor and a tuner. The JDM 3 bar MAP sensor seems to be the weapon of choice. I have the Omni 7 bar MAP sensor though.
Old Jul 21, 2012 | 02:12 PM
AustinB768's Avatar
Thanks, I understand now.
arnoldp
Jan 30, 2013 07:21 PM
Gary@MellonRacing
Lancer Troubleshooting
Nov 26, 2011 05:15 PM
WaldoLS90
Jul 15, 2010 09:41 AM
Icem@n
Aug 14, 2009 03:05 AM
Inprogress
15
Apr 2, 2008 07:40 PM
