How much Boost should i run with my evo green turbo
Old Jul 22, 2012 | 12:00 AM
sdheath's Avatar
Hey guys im new to these forums i recently picked up an 04 evo which has an evo green turbo, hks 272 cams, injen intake/intercooler piping, hks FMIC, HKS exhaust, forged BOV, port and polished head, with aftermarket fuel pump. Although the car has the stock injectors so I was wondering having these mods whats a safe boost to run at that will also give me a good hp put out? Thanks
Old Jul 22, 2012 | 12:41 AM
MR. EVO MR's Avatar
The tune decides!
Don't play with the boost unless you want trouble!!
Old Jul 22, 2012 | 01:00 AM
DsmGuy86's Avatar
Originally Posted by MR. EVO MR
The tune decides!
+1 most deff personal experience had a 2g eclipse decided huh what would happen if i turn this knob up not good and make sure you have a good tuner do it not a guy thats like hey i know what this is i think i had another guy try and tune my eclipse cut a van line to the WGA and got into it in 3rd boost gauge was tapping 30 psi then BOOOOMM there goes exhaust mani gasket down pipe actually blew down a little so yea don't touch the boost with out tuning it good luck
Old Jul 22, 2012 | 01:35 AM
lostsoulsevo's Avatar
upgrade those stock injectors!!!!
Old Jul 22, 2012 | 01:59 AM
Tanro's Avatar
560cc injectors will only support about 32lbs / min on 93 octane based on experience using evo 9 injectors in the older style 4g63 engine.
That said, I'm not an expert on the newer engine. My base fuel pressure was @ 43psi, and my injectors were logging 82% IDC +/- 3%
Old Jul 22, 2012 | 02:50 AM
akeric's Avatar
no offense but the question you asked does not reek of experience so I would say you'd be better off taking it to a tuner to get it tuned for maximum power on your setup with the best fuel available. If someone throws a number out and you set it to that, you'll probably just end up damaging you engine because it isn't tuned for that.
Plenty of tuners in Cali, take the time and the money and get it done right.
Old Jul 22, 2012 | 05:59 AM
sparky's Avatar
There are two "Green" turbos. One of them is refered to on these forums as the Old-School Green(OS Green). This is the original Green turbo.
The other, newer Green turbo, is called the HTA Green. Do you happen to know which of these two turbos is installed on your car?
Old Jul 22, 2012 | 07:09 AM
Thought was another green? The new and improved DBB? The 73hta is journal bearing?
Old Jul 22, 2012 | 08:37 PM
sdheath's Avatar
Thanks for the replies, ya im not sure which green turbo it has, but as far as the tune goes, it has been tuned recently and was tuned at 15 psi. This is what the guy told me that i purchased it from he says its only at 15 PSI because the turbo was brand new less then 200 miles on it and its suppose to be driven easy for the first 1500 miles. He also had a Buschar transmission installed as well as a stage 2 clutch at the time of the turbo install. So now that the 1500 miles has past I was just curious as to whats a safe PSI to keep it at, while also wanting more power.
Old Jul 22, 2012 | 08:40 PM
sdheath's Avatar
It was tuned at 15 psi, but wanted to know if it was safe to tune it up just a bit for the extra HP, Ya im new to turbo cars ive always had N/A cars
Old Jul 23, 2012 | 02:15 AM
DsmGuy86's Avatar
go and get it tuned and allow someone that know a safe level to do it i would strongly recommend you don't just start turning it up by your self unless you wan things to go bye bye take it to a tuner or find a tuner on these forums that do e tunes if you feel comfortable enough to do it that way but i still say take it to someone let them turn it to the safe amount
Old Jul 23, 2012 | 02:57 PM
Runt's Avatar
Yes do not change anything until you've got the proper instruments to tell whether or not you're about to make a costly mistake.
In fact until you either get with someone that has them that can do the tuning for you or get them yourself I would not beat on that car till you know it's right. Buying someone else's abortion is never a good idea.
Old Jul 23, 2012 | 04:55 PM
sparky's Avatar
Does the OP's car have some sort of boost controller on it?
Old Jul 23, 2012 | 07:59 PM
novem's Avatar
Does the car have a wide band gauge installed? If it was tuned, you may notice the check engine light flashing under hard driving ( if it was set to indicate knock ). SD only has a couple of gas stations that sell 100 octane at the pump. If you turn up the boost to 19psi, and don't see knock..you could mix 91/100 to run at least 93 octane to have a little more peace of mind. But it's up to you. If you can, try to get ALL the info on the car you can. I would do a basic tune up/ fluid inspection, and go from there.
N
Old Jul 23, 2012 | 08:49 PM
sdheath's Avatar
Ya it has a self adjusting one in the engine bay......
