How much Boost should i run with my evo green turbo
Does the car have a wide band gauge installed? If it was tuned, you may notice the check engine light flashing under hard driving ( if it was set to indicate knock ). SD only has a couple of gas stations that sell 100 octane at the pump. If you turn up the boost to 19psi, and don't see knock..you could mix 91/100 to run at least 93 octane to have a little more peace of mind. But it's up to you. If you can, try to get ALL the info on the car you can. I would do a basic tune up/ fluid inspection, and go from there.
N
N
It does have a wide band gauge on it, but I havent noticed any Knock. I just had the shop that tuned it a few months back look over everything cause i just had the timing belts replaced and he said everything looks perfect he said he couldnt find one thing wrong with the car. So i guess ill just get bigger injectors and get it re tuned. Thanks
EVOlutionary
134
Apr 9, 2012 02:58 AM
