Sparktech COP CDI vs Non-CDI
Old Jul 31, 2012 | 02:56 PM
masonh's Avatar
can someone help with why should i upgrade to the CDI version.i am in the process of a new build and going with LR2.4 and 6466 and hope to get close to 900whp.
i currently have the old school Sparktech non-cdi and i believe non-sequential COP setup.i see guys putting down 900 on the non-cdi,but are they rarity or are they to good over 40psi and 900whp?
also i have an AEM ems,so if i am going to upgrade shouldn't i go ahead and get the Pro-14 since it is actually a 4 channel sequential or is the pro-12 2 channel plenty?
i rarely see the 14's,but it seems like the way to go if you have an aftermarket ECU,so 2 plugs don't share the same channel.
is the CDI overkill or is it necessary over 800whp?
what do you guys think?also ar ethe 4 channels plug-n-play like the others or will i need to re-wire it to the AEM box?
thanks
Old Jul 31, 2012 | 03:36 PM
antonio010's Avatar
I've never had the non-cdi version, but I did run the sparktech pro12 setup for a while on my old setup. It ran fine for 2 years but then I began to have some random misfire issues. I suspected the m&w box but it was out of warranty. Since I had to replace it, I just went all out and ordered the pro 14 setup. Car has run perfect since. I'm also running AEM. You will need to rewire it coming from a noncdi setup.
Old Jul 31, 2012 | 03:59 PM
boostedwrx's Avatar
I'm sure others could give a better explanation of the difference between the two. What I do know is ER made 900+ whp on the non-cdi : https://www.evolutionm.net/forums/ev...-ignition.html
Old Jul 31, 2012 | 06:47 PM
masonh's Avatar
i saw that and some other guy made 954 with it,but i wanted to know if they were the rare occasion or if that is the norm for these.
also would the sequential non-cdi be better than the regular non-cdi?
Old Feb 16, 2014 | 10:59 AM
17579EVO9MR's Avatar
I too would like to know this. Really since now the non cdi has a sequential system.
SparkTech
Sep 6, 2017 05:23 PM
maknuge
Dec 18, 2015 07:48 AM
BoostWhore
Feb 16, 2014 10:57 AM
SparkTech
33
Mar 21, 2012 06:47 AM
Chamama
13
Mar 28, 2010 07:14 AM
