HELP No BOOST
HELP No BOOST
Sooooo I installed new gauges and a new downpipe.
went for a drive and went full throttle and sounded like it blew the pressure out like an atmospheric b.o.v.
drove it back to the garage and would not go into boost
looking in the motor the small hose from the recirc bov was off where it connects to the metal hose.... driver side of the valve cover.
also the suction tube where it connects to the turbo was off.
im sure these are the causes for not building boost but wanted your guy's opinion
if you are running a maf with the turbo inlet intake not connected along with the bov not correctly installed i dont think your evo will ever run. kind of sounds like trying to be speed density without being properly set up for speed density. connect everything back up and tighten it all down (all piping connections) with some t-bolt clamps.
It was a ****ty day full of disappointment. The e.g.t. gauge was not working and my h.k.s. downpipe is not matching the rear hangars.
Anyways
Update:
I got to the car and the recirc was also off of the the upper I/c pipe. Along with the vacuum line so I'm sure those are the problem. Will update more tomorrow. Thanks for the input
Anyways
Update:
EVOIX-BIZERTA
Feb 20, 2014 07:44 AM
Nyteryder357
17
Oct 2, 2007 06:44 PM
