Some issues, need help...
Old Aug 2, 2012 | 09:34 AM
AEvans190's Avatar
I have two issues with my evo, I hope you guys can help me out...
When I have my A/C on I hear a very loud rattling/clanking noise. I think its my exhaust hitting the oil pan but not 100% sure. Also when the A/C is on the RPM's at idle are very low sometimes down to 400 RPM's. The RPM's will then intermittently bounce up to 1200 RPM's at idle, then back to the normal 850 RPM's or so. There is no order to this just randomly goes through these cycles. This all happens when the A/C is on. The rattling noise is not present when the A/C is off
However I have also noticed when the A/C is off, and when I am coming to a stop and idling, the RPM's will drop to the normal 850 and then bounce up to around 1200. This problem might tie into my next issue... When I give full throttle I feel a power cut or boost cut. I am not sure what is going on, but I know there is not full power. It seems to happen in all gears although first gear has the least issues. I think it happens at any RPM where there is boost.
Let me know what you guys think.
Old Aug 2, 2012 | 10:35 AM
Boosted Tuning's Avatar
Mod list? Is it tuned or not?
Old Aug 2, 2012 | 10:52 AM
AEvans190's Avatar
Full megan racing exhaust
ACT 6 Puck Sprung Clutch/gruppe-s Flywheel
Transfer Case Rebuild by Sheptrans
No tune
Old Aug 2, 2012 | 05:04 PM
AEvans190's Avatar
I might add... with no A/C on the car will intermittently rise to about 1200 RPM's at idle. I want to say while it is doing this, I am losing the power but again I am not 100% sure.
Old Aug 2, 2012 | 06:41 PM
AEvans190's Avatar
Also the A/C will sometimes blow hot air...
CharliEvo8
Jan 5, 2025 10:14 AM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Sev
Apr 4, 2015 09:18 AM
princess33
Sep 14, 2014 08:08 AM
ralliartation
Dec 1, 2011 06:28 PM
