which intake/inlet pipe??
Old Aug 10, 2012 | 09:49 PM
elim0's Avatar
hi guys, i know this topic has been done and i have read a few threads but there have been no definite answers. i am thinking of changing my inlet/intake pipe from my maf sensor to turbo from the rubber to either a silicone/aluminum pipe but am unsure which to go.
i have read the aluminum pipe can mess with the maf sensor due to vibrations as it doesnt give room to flex/play. i also have cams, and was wondering if this is true or not and whether or not i should just go with a silicone replacement over the metal pipe.
any feedback or personal experience would be appreciated. thanks , cheers !
Old Aug 10, 2012 | 10:11 PM
thatguy5's Avatar
ets intake with vibrant filter. best setup EVER
Old Aug 11, 2012 | 12:58 AM
Thore's Avatar
Can look into speed density and remove the MAF altogether.
Old Aug 11, 2012 | 04:05 AM
elim0's Avatar
will the ets intake mess with the maf since my cams DO make my engine move quite a bit i notice(esp when warmed up).
(edit: i also note i have a hks smf intake in a hks cf box which im quite fond of and dont want to remove****)
i dont know much about removing the maf sensor / putting speed density in ?? :s
Old Aug 11, 2012 | 06:30 AM
Craig King's Avatar
Perrin Intake kit.
Old Aug 11, 2012 | 06:48 AM
djdnav's Avatar
If you have issues with your engine moving a lot, then get stiffer mounts.
Old Aug 11, 2012 | 11:46 PM
Thore's Avatar
Just get a nice inexpensive silicone intake and call it a day. Usually can be purchased used for around $100 or less.
I have a standard Samco intake that looks almost identical to any other brand of silicone intake. Hasn't really given me any trouble. Just replace the worm clamps with T clamps and shouldn't have to worry about anything beyond that.
MAP Generic Silicone intake - $109
http://www.maperformance.com/map-3-t...p-evo-3ti.html
T-Bolts $3 each
http://www.maperformance.com/clampco...4106-0350.html
Old Aug 12, 2012 | 04:14 AM
elim0's Avatar
T-Bolts $3 each
cheers ill probably just go with this idea ~ not too fussed. thanks guys !
Old Aug 12, 2012 | 04:48 AM
9evolution's Avatar
+1 on the perrin intake.
Old Aug 12, 2012 | 05:37 AM
boostaddikt's Avatar
go speed density
Old Aug 12, 2012 | 08:44 AM
Craig King's Avatar
Originally Posted by boostaddikt
go speed density
Any reason in particular? The stock MAF has been proven to support well past 500hp.
Old Aug 12, 2012 | 11:39 AM
Boosted Tuning's Avatar
T-Bolts $3 each
You dont need T-bolt clamps on the intake. It doesn't see pressure/boost and using T-bolt on it is not needed.
Old Aug 12, 2012 | 05:47 PM
IXrunner's Avatar
(sorry I dont know how to resize)
This is my Samco intake had it for years and still looks great. Fit and finish is easily the best.
Old Aug 13, 2012 | 11:00 PM
Thore's Avatar
Bah, I must have not been thinking correctly. You are 100% right.
Old Aug 14, 2012 | 09:15 AM
elim0's Avatar
just curious also.. do any of you guys have a silicone intake/inlet pipe yourself and is it hard to install.
i have a few friends with wrx's/sti's and they say its a real pain and had it done at a shop, but im not sure if it was difficult due to fitment of their pipe/engine position or the silicone being hard to fit on itself??
