Tial 44mm wastgate problems
Old Aug 12, 2012 | 08:41 PM
evo1008's Avatar
What are symptoms of a bad boost controller because I'm getting wastegate flutter/chatter and the diaphragm is not riped everything seems good.any thing else?
Old Aug 13, 2012 | 06:22 AM
TiALSport's Avatar
wategates do not flutter or chatter, you are probably hearing compressor surge
Old Aug 13, 2012 | 06:30 AM
evo1008's Avatar
What is the cause of this ?
Old Aug 13, 2012 | 06:31 AM
TiALSport's Avatar
trying to shove more air into the engine than the engine can take at a specific RPM
Old Aug 13, 2012 | 06:32 AM
jeffbeagley's Avatar
Does it only do it in a high gear ( 4th-5th ) and at low RPM? The duty cycle of your boost controller may be low causing it to "flutter". This is perfectly normal.
Old Aug 13, 2012 | 07:02 AM
EvoVIIIFL's Avatar
Read this and you'll fix the flutter issue
http://highboostforum.com/forum/show...OV-information
Old Aug 13, 2012 | 07:06 AM
evo1008's Avatar
Well it only does it at full boost and now the boost is spiking like crazy even when the boost controller is closed.i was thinking the boost controller is no good. But when it is complety shut why would it spike over 30 psi it should only work of the wastgate spring.
Old Aug 13, 2012 | 07:12 AM
TiALSport's Avatar
try it with no boost controller - hook one line from the pressure source to the bottom port of the wastegate, leave top port open
Old Aug 13, 2012 | 10:05 AM
evo1008's Avatar
Just tried it . It works like that perfect. So I guess it is the boost controller ?
Old Aug 13, 2012 | 12:09 PM
TiALSport's Avatar
well it's not the wastegate or the turbo
Old Aug 13, 2012 | 12:31 PM
evo1008's Avatar
Awesome thanks for all the help
