Aftermarket fuel regulator
Old Aug 17, 2012 | 02:41 PM
KOOLER's Avatar
Gentlemen,
when replacing fuel regulator with aftermarket one (have an impression my detschwerks pump is overflowing on low voltage), what fuel pressure should I have on idle? And if my idle is ~1,000 rpm?
Thanks!
Anton
Old Aug 17, 2012 | 02:48 PM
240Z TwinTurbo's Avatar
Unplug the vacuum line to the regulator and insert a small bolt to seal. While the engine is running the pressure should read ~46psi.
Old Aug 18, 2012 | 05:48 AM
KOOLER's Avatar
engine rpm @ idle does no matter?
