If cost was not a factor; Stock frame or T4 setup for 450-550 hp
Old Aug 26, 2012 | 09:37 AM
  #46
SmurfZilla's Avatar
Originally Posted by forc3 f3d
the CBRD lmp kit looks pretty damn appealing with a 33rb. flows better than any stock frame, still makes awesome USABLE power and sorta limits you so you dont want to make 700+ one day
if i was starting from scratch i would consider it.
I'm probably a week or two from having to make a decision and move forward.
Old Aug 26, 2012 | 09:54 AM
  #47
03whitegsr's Avatar
Originally Posted by SmurfZilla
Is there any factual info to support some peoples assertion that the garrett based turbos don't flow well in twin scroll config.
Right now i'm between a 5857CEA/5858CEA, HTA82 or GTX3071.
Its hard trying too look up info for these choices and there are so many intelligent opinions pro and con for these choices it makes picking difficult.
It's more of a housing issue then anything else.
The T3 twinscroll stuff has been shown to choke badly on multiple platforms. It spools awesome and makes great torque, but it falls flat on it's face at higher power levels and engine speeds.
The Garrett housings have shown to not hold up well to high EGTs. Small housings help produce high EGTs so until you get into the larger housings, this is a pretty big concern.
I'd feel comfortable with a Garrett T4 divided setup in either a GT35 or GT30 turbine wheel for a street car. I don't think I'd use one for road racing though. The standard BWs also have some nice sizing options on the wheels and are a good value, they just use massive housings that can be difficult to fit.
Old Aug 26, 2012 | 10:59 AM
  #48
Acree's Avatar
Smurf,
Are you planning on running E85 primarily or 93?
-Acree
Old Aug 26, 2012 | 11:29 AM
  #49
SmurfZilla's Avatar
E85 primarily. I went high compression with E85 in mind. I have 2 E85 gas stations available. One 10 miles away from work and one 15 miles away from home (its on my way to and from Raleigh so its not out of the way). When i built the car where I lived in Atlanta I had an abundance of E85 gas stations to choose from.
I run 93 mostly because I'm too lazy to get E85.
Old Aug 26, 2012 | 12:32 PM
  #50
Acree's Avatar
Do yourself a favor and stay away from the stock frames. I just had my first real SD tune on 93. It eeked out 352hp. No matter what happens, it knocks around 6k. My 10.5:1 pistons and the Black don't make for a great pump gas combo. E85 on the other hand and it picks up 300hp
-Acree
Old Aug 26, 2012 | 12:53 PM
  #51
SmurfZilla's Avatar
Its funny you should say that. yesterday I decided I'm more then likely keeping my setup and selling the turbo for something smaller.
I'm leaning towards the 5857CEA or the 5858CEA. I'm waiting on some people to get back to me that are smarter then me on their educated, experienced opinion.
Old Aug 26, 2012 | 02:11 PM
  #52
SmurfZilla's Avatar
And the GTX3076R........dammit.
So Arcee you're having issues with your setup?
Old Aug 26, 2012 | 03:40 PM
  #53
deeman101's Avatar
Avoid GTX3076r. Go above or below to GTX3071r or GTX3576r. It doesn't look like sticking that big compressor wheel on a gt30 housing gives much of an advantage to just going gt35. 240z twin turbo has results to prove that.
Old Aug 26, 2012 | 04:28 PM
  #54
SmurfZilla's Avatar
I've been reading his thread slowly, among others. Thanks for the tip.
Old Aug 26, 2012 | 05:12 PM
  #55
SmurfZilla's Avatar
Doesn't look like the GTX3576R is part of their regular lineup.
From the looks of 240's testing it seems I do need to give that turbo a serious look.
Old Aug 26, 2012 | 05:24 PM
  #56
SmurfZilla's Avatar
GTX3582 vs HTA82?
I'm slowly creeping up
Old Aug 26, 2012 | 06:56 PM
  #57
masonh's Avatar
+1
450-550whp puts you right in the middle of a basic fast car or a really fast car.
i still say go with a 3582 and just detune it a little until you want to go fast again,trust me it will happen.you will miss that 6265 sorely after a few weeks of 500whp.
Old Aug 26, 2012 | 07:12 PM
  #58
Acree's Avatar
I wouldn't say I'm necessarily having issues with my setup. It was simply a lack of foresight on my own part. I figured I would always be living within a few miles of an E85 station. I moved about 30 minutes away from the closest one, and now I'm forced to primarily use 93. The good part is the Evo is now my second car, which means it will get to stay in the garage and let can rack up the miles on the daily.
The setup was just not selected for 93 primarily. The high compression and stock frame turbo mean that my setup produces much more back pressure than 93 likes to put up with. I figured with 10.5:1 pistons, I would be on the safe side and be able to run at least ~25psi on pump, but with the machine work that had to be done to my block and head after my debacle with MAP, I'm sure my compression ratio is at least 10.5:1 or higher. The truth is, no one knows.
Until I can get the ***** (and funds) to swap over to a BW7670 or maybe a little bigger, my Black is just going to have to make due.
-Acree
Old Aug 26, 2012 | 07:17 PM
  #59
deeman101's Avatar
These are results from a gtx3582r (most likely...its the biggest garrett gt35): https://www.evolutionm.net/forums/ev...ol-inside.html
I believe 240z also has a gtx3582r to test. Or wants to test it.
Old Aug 26, 2012 | 07:32 PM
  #60
masonh's Avatar
what was the debacle with MAP about?
wouldn't the billet Titanium wheels of the BW turbos actually be heavier and laggier than the billet aluminum?
