Turbo drain (pan side) fitting
Is there a fitting or an adapter that some one makes that will bolt on to an evo 8 pan and take a -10 fitting or just have a 1/2 pipe thread on it? I have searched around a bit and am having trouble finding this.
This is meant for the drain flange on the turbo...not sure if the two are interchangable
http://streettunedmotorsports.com/pa...bo_fitting.htm
They used to have a complete oil drain line replacement kit that replaced with AN or push-lock fitting on both ends. STM is known to have all sorts of items...give them a call. They'll have gaskets for the fittings too
Found it...one of those fittings is the one you need. You could get the kit which is a little pricey, but u could also try to see if they'll cough up just the pan side fitting you need
http://www.streettunedmotorsports.co...proclassic.htm
tscompusa2
Nov 12, 2011 02:57 AM
