highest compression for pump gas
Old Aug 28, 2012 | 05:45 AM
RjRacing05's Avatar
All these posts are completely false statements and are common rumors. I run 10:1 compression on 93oct with my 2.4LR i built w/o any issues, all you need is a good tuner. Sure I'm not making the 700+whp on that tune due to boost turned down to 26psi and pulled some spark advanced timing, but it drives strong w/o any knock. I even built a inergra type r a few years back running 11:1 compression w/ 35r that was daily driven on 93oct that Norris tuned and it still runs flawlessly. Again, you can run higher compression on premium gas all that's needed is a great tuner, lower boost, and some timing or spark pulled back.
Ps: I don't have any dunno numbers yet from my current build but I would guess I'm in the high 500s on 93oct comparing it to my last setup on the stock block.
Old Aug 28, 2012 | 05:50 AM
mrboost05's Avatar
same here on my second 10.1 motor most good tuners are not having a problem running 30lbs on pump gas with 10.1 as long as the ignition is up to par and you have a good tuner shouldent be any problems mason any info on this Torco fuel accelerator ?
Old Aug 28, 2012 | 06:44 AM
masonh's Avatar
http://torcoracefuel.net/pro-accelerator.html
http://torcoracefuel.net/2-docs/acce...r-ratio-93.gif
1 quart which is about $25 if you just buy it by the quart will raise an EVO tank of 93 octane up to 100+octane.1 quart will raise 10gallons to 104octane.you can also buy a 5 gallon bucket for like $300 shipped which is 20 quarts.the stuff works as advertised.i have tried it.
you missed the entire point.fact is that you could run 29-30psi with the same timing on your car if you were at 9:1 instead.the extra 2-3psi of boost you can run with lower timing will outrun the gains you got off going from 9:1 to 10:1.fact is 2-3 psi of boost is good for 60+hp on that GT35 and going from 9:1 to 10:1 increase in SCR is good for maybe 25hp.
if you can run the same boost on 93 at 9:1 as you can on 10:1 then by all means go with the 10:1,thing is most cars can't.fact of the matter is there is a point where rasing SCR will hurt you on 93 octane,if you don't believe it then you can't be helped at this point.
Old Aug 28, 2012 | 11:07 AM
jons0n's Avatar
A high CR also increases the risk of detonation with low octane fuel. Regardless of tune, the risk is still there.
Old Aug 28, 2012 | 02:02 PM
94AWDcoupe's Avatar
Originally Posted by masonh
agreed,you can go 10:1,but you peak boost will be low enough that you will loose power overall over 9:1.if i was going to build an EVO motor that would only see pump gas,than i would probably even go down to 8-8.5:1
I agree 100%
8/1 would be my choice for low octane
Old Aug 28, 2012 | 09:51 PM
JohnBradley's Avatar
No more than 9:1 for a dual purpose engine, E85 and low boost on pump then 10:1 but based on my experience 20-21psi is really the safe limit on 92. A straight pump motor I would still probably leave it at 9:1 as the 8:1 and 8.5:1 motors just dont seem to have the snap I prefer and really seem to run out of octane at the same point, least on 92.
FWIW I made 648/477 at 29psi on 92 octane without additives.
Old Aug 29, 2012 | 06:03 AM
evoboy2006's Avatar
Hey john will there be big power diff if I ran 9:1 compared room 10:1 on e85? I feel like the pump e85 is inconsistent.I have 93 over here don't know what I can get out of that with 6266 thanks
Old Aug 29, 2012 | 06:04 AM
masonh's Avatar
John,what was the SCR of that motor that made 648 on pump,9:1?
if you can make 29-30psi with a 9:1 SCR,shouldn't you be able to go a little higher than 22psi on a 10:1 motor.i figured only a few pounds of boost per SCR point?
Old Aug 29, 2012 | 07:05 AM
evoboy2006's Avatar
My question is will 10:1 motor on e85 make more power then 10:1
? Bboth same modd besides compression
Old Aug 29, 2012 | 07:49 AM
masonh's Avatar
if you meant will 10:1 make more than 9:1 on E-85,then the answer is yes.you will probably gain 3-4% power overall.
on pump gas(93 octane)i would say that 9:1 would make a little more power in the upper rpm range than 10:1,just because you can make more boost.boost=power
Old Aug 29, 2012 | 08:29 AM
3-4% max but for the most part it seems they make the same power depending on boost. The thing to keep in mind on an 800whp car 3% is 24whp, not really the end of the world if it keeps cylinder pressure in check.
That was a 9:1 motor that made that power. It seems odd but thats how it tunes out with 10:1. I am basing this on knock voltage and then when the random knock spikes start to occur. You might be able to run a little more but it would be on the edge of issues so I feel confident saying 22psi. Obviously cams and if its a MIVEC car will go a long way to contribute how much you can run. Keeping the DCR in check with cam timing is an easy way to run more.
I prefer to run 9:1 motors just so I can go back and forth easier and still make good power on either.
Aaron
.DoT.
55
May 13, 2016 06:30 AM
VRP
Apr 13, 2015 11:58 AM
bryonboals
Aug 4, 2013 06:41 PM
tiggerx3
10
Jul 27, 2013 06:39 AM
MitsuRalliArt
May 4, 2004 09:17 AM
