Pte 6262BB won't spool on 2.0L block.
Old Aug 29, 2012 | 06:39 AM
GBAILEY472's Avatar
Hey, Car was on the Dyno yesterday, and we couldn't get the turbo to spool. It would hit full boost (17Psi) at 7500rpm and at 3000rpm -200 Trq
We did boost leak, compression, leak down... all the tests were properly done..
Anyone have and idea ? So far, Ive been told my injectors are to big 1425 for 94oct. and my GSC S2 cams might be an issue also..
Please help me out guy's
Thanks
MOD LIST
MAP T3 Exhaust manifold
MAP 3inch downpipe
Precision 6262 Ball Bearing turbo PTE 6262BB
4"ported inlet 2.5 outlet
T3 Vband .82 a/r
Custom 3inch Upper intercooller piping ( Short route)
Battery delete ( in trunk )
AMS F1 Intake Manifold
AMS Fuel Rail
Boomba Throttle body
1425 Injector clinic injectors
Spoolin coil on plug system
ETS Intercooler
MUSE LICP
TIAL BOV
TIAL 44mm external Wastegate
Wiseco Coated piston 9:0:1
Manley H-Beam Rod
Cometic Head Gasket
ACL bearings rod
ACL main bearings
ARP Headstud,
ARP Mainstuds,
Brian Crower Single Springs
Bran Crower Titanium Retainers
Balancer shaft Delete kit
Areomotive 340L Fuel Pump
GSC S2 Cams
Vi-Pec ECU Standalone System
Aquamist HFS-5 Meth Injection with Guage Display
AEM OIL pressure guage
AEM Boost Pressure guage
Grimspeed Electr. boost controler,.
Omni 3 Bar map sensor.
NGK wideband
STM SS Clutch Lines
JM Fabrication SS Lower radiator pipe
JM Fabrication SS Upper radiator pipe
Moroso Oil Catch Can
Sheptrans Stage 3 Transmission
■New 1st gear synchro
■New 1-2 shifting sleeve
■New 2nd gear synchro
■New 3rd gear synchro
■New 3-4 shifting sleeve
■New 4th gear synchro
■New 5th gear synchro
■New 5-R shifting sleeve
■New Reverse Synchro
■New input shaft seal
■New shaft end seals
■New axle seal
■New 3-4 fork
■New input shaft bearings
■New high strength roll pins
■New 1,2,3,4,5,R synchro springs
■Neodymium magnet
■Bead blast
■New thrust plates
■New thrust plate retainer
■New Oil guides
■Shims
■Billet output tube
■4.11 final drive upgrade
■ REM ISF gearset with rails and hub/sleeve
Sheptrans Stage 3 Transfer Case
■CAD engineered Klinglnberg Palloid tooth profiles
■No reduction in tooth width along the gear
■Robotic CMM scanned for tooth profile perfection
■Computer controlled heat treatment
■Anti-fatigue shot peening treatment
■8mm to 10mm bolt upgrade
■New pinion bearing set
■New seals and o-rings
■Reshimming
■Neodymium magnet
■ Quaife LSD
Sheptrans Upgraded Rear Diff
Exedy Twin carbon Disk Clutch
Techna-Fit SS Clutch Line
Fidanza short throw shifter
AMS Delrin Shift Knob
Old Aug 29, 2012 | 06:43 AM
nyc 93-2jzgte's Avatar
have you checked the condition of the turbo? perhaps it is blown. an smoke at WOT or in/out shaft play?
Old Aug 29, 2012 | 06:48 AM
DDATuned's Avatar
Sounds more like a turbo issue. Take the turbo off and check compressor and turbine blades.
Old Aug 29, 2012 | 07:18 AM
Steven's Avatar
It is for sure not the cams and those injectors should have no problems on pump gas. It's most likely a problem with the turbo or wastegate. Is the wastegate stuck open? Is there any strange noise or smoke while the turbo is spooling? Will the car idle and cruise correctly?
Old Aug 29, 2012 | 07:19 AM
Pirana's Avatar
sounds like a wastegate/boost controller issue.
Old Aug 29, 2012 | 07:37 AM
GBAILEY472's Avatar
Turbo is brand new... no issues. Wastegate is unplugged ... plz keep sending ideas guys,
Old Aug 29, 2012 | 07:41 AM
Steven's Avatar
The Grimmspeed boost controller is unplugged therefore running wastegate pressure?
Old Aug 29, 2012 | 07:43 AM
goosey2099's Avatar
^ and that would make about 17 psi
Old Aug 29, 2012 | 07:44 AM
GBAILEY472's Avatar
yes
Old Aug 29, 2012 | 07:45 AM
masonh's Avatar
sounds like a winner,check and see if you have the 17psi spring in the WG and if so,you know that's what's up.
Old Aug 29, 2012 | 07:47 AM
GBAILEY472's Avatar
but then why would only hit full boost at 7500rpm ?
Old Aug 29, 2012 | 07:48 AM
okevolutionVIII's Avatar
Wastegate or BOV bleeding off air is my guess.
Old Aug 29, 2012 | 07:57 AM
Steven's Avatar
Pull your wastegate outlet/dump and see if the valve is stuck open. If you have a dump tube, I usually undue it then use a mirror and flashlight to look at the valve. I use a bicycle pump with a gauge to pressure the lower port on the wastegate to ensure it is opening at the proper pressure and doing it smoothly.
Are you running a catalytic converter that could be clogged/broken?
Old Aug 29, 2012 | 08:42 AM
Pirana's Avatar
bang, right on the kisser!
Old Aug 29, 2012 | 08:56 AM
wreckleford's Avatar
If that all checks out ok then check that you don't have any rags or newspaper stuffed in your intercooler piping from when the car was taken apart. I've seen that happen before, found it in the intercooler inet.
